OK, so I finally got off my rear and decided to post some pictures of my intended build. I've started down a path but am having some second thoughts and hoping to get some feedback.
As history, I have a 10 yr. old home/new construction that I designed loosely based on a stock home plan. Didn't plan for HT so it is what it is in terms of layout options. Based on space, planning on a 16:9 120" diagonal screen.
I've spent a few cycles studying layout options, and settled on progressing with the following (with some reservations):
3D Home Architect version:
Sketchup version:
This area seemed to make the most sense to me but, it's unfortunately directly under our master bedroom so sound isolation is to be of considerable importance. if I have any hope of retreating to the man cave while wife is sleeping. With that in mind, I will be doing DD/GG, decoupled walls etc. My biggest concern right now is that I have both return and forced air trunk lines running right along the beam on the theater side. Pictures follow:
Return is along beam (8x20 trunk, way oversized) and forced air next to it is 8x16". Original plan was to just move both to the other side of the beam just before the entrance wall. Had a sheet metal/HVAC guy out and he immediately talked me out of moving the forced air trunk over due to the number of corners needing made and that it would restrict airflow to that end of the house. I asked about tweaking dampers in the other ductwork etc. but was advised that I may never get it right. So, while he was there I suggested just moving the return trunk over to the opposite side. and moving the forced trunk along side the beam on the theater side (where the return was) and just doing a soffit around it. A much better option. The quote came back at $1700. I can do this myself for under $200 materials, but that's a side note.
So, what I am concerned about is if I can effectively damp noise with this trunk line (forced one) enclosed in a soffit. I have two 13' runs of round 6" duct running from it to the right wall feeding two master bedroom registers, and a third shorter one at the end feeding master bath. This is my dilemma right now and has caused me to put things on hold. I would plan to replace the lateral runs with flex duct but am concerned about getting at least "good" isolation to the trunk line in the future soffit.
After going back to look at my layout again, I started thinking about the space on the other side of the beam, and came up with the following alternative (note change in stairs, with landing now but can only see getting around 32-34" square):
I discounted this space originally due to to the 8'x16" block indentation which is part of the front stoop and overall depth, but it would be a lot less worry in terms of soundproofing (little HVAC) but more challenging from a framing standpoint with the stairs and all of the steel support posts around stairs etc.
Also concerned about side to side spacing of theater seating and surround speaker placement on the indented portion. May have some challenging issues the sound quality.
To summarize, I am hoping to just continue on the path I'm on as I have over half of the walls built by now but I'm not too far along that I couldn't switch things. The theater where it's at now just feels better to me, if you take the trunk line out of the equation. I like the idea of having the door to the storage area and would be concerned about general sound issues with the option shown, where to put my equipment closet etc. etc.
Hoping to hear some comments and advice on this.
Floyd
Sketchup version:
Floyd
