Originally Posted by tribalnoise
the first repair was because one of the speaker outputs was causing a popping noise from the speaker. but the last 3 times i have sent it in is for the same "problem" and it's already showing signs of occuring again
. intermittent video dropouts. eventually i expect some of the inputs will stop working unless certain connected devices are on at the same time. i believe it is an hdmi handshake issue between my tv (panasonic th-42pz85u) and the receiver but onkyo has continued to dismiss that idea. i have tried different cables and connecting the devices to different inputs. so frustrating!!
. intermittent video dropouts. eventually i expect some of the inputs will stop working unless certain connected devices are on at the same time. i believe it is an hdmi handshake issue between my tv (panasonic th-42pz85u) and the receiver but onkyo has continued to dismiss that idea. i have tried different cables and connecting the devices to different inputs. so frustrating!!The 606 had a HUGE problem with the HDMI boards, and they eventually upgraded me to a 607 because they couldn't replace the HDMI boards fast enough to keep up with demand, and even when they did the problems persisted. Hopefully that's not the issue with yours but it could be since the designs are very similar. Maybe they replaced your HDMI board with a 606 board the first time you sent it in?
When they fixed your rx, how did they describe the work that they did... ie, what did they "fix"?
