AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Onkyo TX-SR607 Thread
The "Official" Onkyo TX-SR607 Thread - Page 84
post #2491 of 2524
Originally Posted by mikevoth View Post
Onkyo TX-SR607
Klipsch RB-61 II bookshelf speakers on stands
Klipsch RW-112 sub
New here. Have a 607 sound question. Ran the audyssey sound setup, but the sound is too quiet and the sub is non-existent. Is there a better way to set up the speakers manually?
Using original Mic on Tripod?
Set Sub Volume knob to 50% and any frequency knob to max. before Audyssey calibration.
Small room?
Check Dynamic Volume setting
Yes, you can setup manually ... just go down the list.
What source material are you using as a test? I watch DVD and Blu-Ray movies around 50 volume.
post #2492 of 2524
Originally Posted by Tesla1856 View Post
Originally Posted by emossg View Post
White dots disappeared when I changed pixel format from YCbCr 4:4:4 to 4:2:2. It seems that not any of my 4 HDMI cables are capable of handling amount of data that is required for that pixel format.
Good to hear you got it working. So your TV isn't HDMI 1080p-60Hz 16:9 aspect (1920x1080)?
If you are having EDID problems, you can force parameters (research in TV's manual) through Catalyst in "HDTV Support" tab-section.
My HTPC is set for default of YCbCr 4:4:4. Most of my cables are:
10ft. HDMI v1.3a cables (MonoPrice w/ Ferrite-Rings 28AWG/Cat2/340Mhz #3958)
Except for to projector (notice gauges) ...
Final 57ft HDMI chain to Epson 8350:
Onkyo TX-sr607 7.2 HDMI AVR
2ft 24AWG CL2 High Speed HDMI Cable w/ Net
4X2 True Matrix HDMI 1.3a Powered Switch w/ Remote (Rev. 3.0) (MonoPrice # 5312)
45ft 22AWG CL2 Standard Speed w/ Ethernet HDMI Cable
HDMI Active Equalizer Extender Repeater (MonoPrice # 2849)
12ft 24AWG CL2 High Speed HDMI Cable w/ Net
Epson Home Cinema 8350 Projector
18 ft. from wall/screen = (96" or 8ft diag. image)
Tesla,
I'm looking for EDID overide solution for the SR607. I have Acer Revo 3600, with latest NVIDIA driver, connected to the SR607. However, the Audio support format does not show HD audio format, only Dolby 5.1. I've learned that it could be EDID problem, and an overide is needed. Do you get HD Audio formats on your HTPC? did you have to do EDID overide so that your HTPC uses correct HD audio formats?
TIA
post #2493 of 2524
Originally Posted by bodhi78 View Post
Tesla,
TIA
Not yet as far as I can tell, but I'm pretty sure it's a limitation of XBMC Eden v11. Frodo v12 is just released, but I haven't upgraded yet. I created a full Blu-Ray rip of my Avatar BD (33 gb with DTS-HD lossless) that I am testing with.
EDID Override? No, the Gefen unit is just there to "fake-out" the HTPC when the Onkyo and everything else is off. Works perfectly.
It's my understanding, to get HD-Audio to work from HTPC (or media player) you need:
1. Properly encoded source file
2. Hardware support (for me AMD Radeon 5xxx ... they say yes it does)
3. Software support (for me XBMC)
... and HD-Audio support at the decoding device (which we both already have with the Onkyo 607).
If I was you, I would be looking real close at Acer Revo 3600. Do you guys have a forum? Even WD-TV SMP only support Dolby True-HD ... DTS-HD gets core 5.1 only.
I'll try to remember to post back here when/if I get it working. Maybe you can do the same. However, we have very different Input machines. The Onkyo 607 can't be the problem because all HD-Audio formats play fine from HDMI connected real Blu-Ray player.
Personally, I hear very little difference between good 5.1 and HD. To me, it's just the extra little Rear channel.
post #2494 of 2524
Thanks Tesla,
I'm pretty sure the Acer Revo 3610 (sorry about the typo in my post, it's actually 3610) with latest NVidia drivers can support HD Audio. Some XBMC members have got it to work long ago with MPC. I've just installed XBMC Frodo, hence am testing it with a Blu-ray rip MKV. The Onkyo lits up its DTS Master LED when I play the video using XBMC, but the video FPS is slow to a crawl smile.gif and no sound. I've did all I could with troubledhooting instruction from XBMC forum, but one thing I have not been able to do is the EDID overide, I'm still looking for the inf file.
One more thing: the Nvida Control Panel showing the TX-SR670 correctly. But Win 7 sound device does not show any of the HD audio format supported, only Dolby 5.1.
-bodhi
post #2495 of 2524
Thanks Tesla,
-bodhi
Ok, well then our systems are pretty similar (except you have nVidia and I have AMD) ... but really, that's a pretty big difference.
If Onkyo 607 is lighting up DTS-Master then I think it's getting there. But maybe due to HDMI lip-sync ... if video is broken then audio can't play.
Are you running DXVA2 and WASAPI ? Not sure what new HD-Audio looks like yet or new recommended settings.
I think EDID override would be to fix Onkyo 607 (the way it looks to HTPC) but we know Onkyo 607 plays 1080p and HD-Audio fine because real Blu-Ray players work fine.
Again, look at Revo 3610... nVidia chipset and drivers. Not Windows because there is no decoding there (it just sends bitstream to Onkyo). Not even on-board sound-card because nVidia HDMI is in complete control.
post #2496 of 2524
I have a problem with the mmpu setting on my receiver after a firmware update, does someone know which part is storing the MMPU setting so I can replace it. I thought it would be the hdmi board but replacing that didn't fix the issue.
post #2497 of 2524
@Tesla,
I've looked around some more. Just what you thought, people have reported that the Acer Revo 3610 Nvidia chip does not support bit stream HD Audio smile.gif. Here is what poofyhairguy said in XBMC forum:
http://forum.xbmc.org/showthread.php?tid=85665&pid=647868#pid647868
I guess Multi channel PCM is what I will have to use to get HD Audio out to the TX-SR607.
post #2498 of 2524
Have a 4 year-old 607 that has begun to show the HDMI handshake problems noted in this thread. Not willing to attempt to switch out the culprit capacitors, as per video instructions. Do the later Onkyo model receivers all suffer the same problem?
post #2499 of 2524
prosete,
seems all Onkyo models suffer from some kind of gremlin. Depending on which model depends on which gremlin. The 2012 units have better HDMI boards. It may be worth a call to Onkyo Product Support concerning your 607. My 607 has been very problematic, Onkyo Support has been very helpful....a little slow, but helpful.
Todd
Edited by avcht68 - 2/17/13 at 11:09am
post #2500 of 2524
Blueone0,
I feel stupid, I wasnt aware the 607 was able to update the firmware. How did you do that?
And also, could you define MMPU setting?
Todd
Edited by avcht68 - 2/17/13 at 11:10am
post #2501 of 2524
I ended up calling support and they verified it's the hdmi board. Was told the 607 came out when 108i was predominant resolution (which it's what I had at the time). Now that I use 1080p for all my video sources, apparently the 607 board has problems tuning in and it can take several minutes for the handshake to complete the signal. Support offered a trade-in for a newer model. I then decided to purchase the NR616 and have not had the handshake problem (yet). It only cost me $40 more than the reconfigured model I would have received on trade in. Will see...
post #2502 of 2524
Originally Posted by avcht68 View Post
Blueone0,
Todd
Ed
post #2503 of 2524
Originally Posted by prosete View Post
Was told the 607 came out when 1080i was predominant resolution ...
When it's broken, I suppose.
I have always had 1080p sources and have never had a problem with them and the 607.
post #2504 of 2524
I'm curious, how do we update the firmware on these units?
post #2505 of 2524
You play a firmware CD-DVD into them via SDPIF. But really, on the Service Centers are suppose to do it. You can brick it easy.
There isn't an important update as far as I know.
post #2506 of 2524
I just moved my 7.1 speakers around (to center on the new projector screen) and re-ran Audyssey calibration.
Movies and music sound great but ... is 75 really max. volume? Can any of you get it up closer to 99?
Max on movies sounds best around 50-55 ... but for music and concerts I would like to see if I could go higher (speakers are still pretty good and sound like they could handle more). The room is fairly large.
Well, the 607 is still going strong. Not a single problem and we use it 24/7 and I drive it pretty hard sometimes.
I moved all my old speakers to Exercise Room, and bought a whole new set of Polk-Audio speakers for the main room (and re-ran Audyssey).
I'm pretty sure my max volume is still 75, but I just tried (on a DolbyDigital 5.1 concert) and I was afraid to turn it up past 65. The sound was still clear and defined (and obviously very loud) but I was not afraid for the speakers ... more like a window or my ear-drums. eek.gif
post #2507 of 2524
Fix broken Display on TX-SR607
There could be a second failure when Display is not working:
Here is the link to:
http://www.hifiengine.com/library/onkyo/tx-sr607.shtml
I don't want to post it again...
hopefully this will help someone
regards Nils
post #2508 of 2524
I've read several pages of this thread and see that some are having issues with power-up after the unit is off overnight. I'm having a similar issue and was wondering if anyone could give me some input on this...I've posted on a couple of other boards until someone suggested this site, so I'll paste below...
I'm having an issue when my components have been powered down overnight or for several hours. I have a Samsung 55" LED 6150 Series Smart TV, a DirecTV HR24 receiver and the Onkyo TX-SR607 (along with a 5.1 surround system). When turning the components on it will take 5-10 minutes before I get audio/video. I have the Dolby PLII, PCM, HDMI and Audyssey indicators in the display when first powered up and after the 5-10 minute range, the Dolby Digital symbol will begin flashing and when it remains solid, the picture and sound will come on and the display indicators on are Dolby Digital, HDMI, DSP and Audyssey.
When I turn the Onkyo on independently and use the tuner function, my radio presets will work (I have sound) immediately.
I know the video for the TV comes on immediately because i can get a picture when I try to use a Smart app via the TV remote.
I do have a 25-30' HDMI cable that was pre-installed in the walls.
After the components (TV, Onkyo, DirecTV) have been on (with picture and sound), I can turn them off and back on after a few minutes and the audio/video comes on immediately.
We recently moved and I was having no issues with the receiver previously although I was using a different Samsung TV (LN52A650) and only had a 4" HDMI cable from the TV to the receiver.
I also removed the receiver from the setup and connected the DirecTV receiver directly to the TV via the same HDMI cable (after the components had been off overnight) and I immediately get audio/video. I then changed the cables back to their original configuration and once again had the 5-10 minute delay before I had audio/video.
Would this be an indication that the HDMI board is going out on me (as I read in some of the posts here)? Thanks for any insight...
post #2509 of 2524
Originally Posted by nilsvoss View Post
Fix broken Display on TX-SR607 . There could be a second failure when Display is not working:
Here is the link to: http://www.hifiengine.com/library/onkyo/tx-sr607.shtml
Thanks for posting this. I don't have this problem, but someone else earlier in this thread did. Without having it on my bench, I thought it might have been a display-tube cold-solder-joint or driving display voltage problem.
Thanks for the introduction to HifiEngine.com and the true Onkyo 607 Service Manual.
I have published some similar consumer electronics component and/or board level repairs. I never really know the best place to post them. I have posted some here and on ElectronicsPoint.com . Would you agree that HifiEngine.com is the best place for such postings?
Edited by Tesla1856 - 4/5/13 at 1:38pm
post #2510 of 2524
Well, the Onkyo should never be unplugged or powered all the way off. It should be in "Standby" (to allow remote to turn it on). It also helps if it's turned on first before others (like with a Harmony sequence). You could try turning on HDMI-CEC (RIHD) and that should keep the HDMI board powered-up during Standby.
As far as the rest, the new long HDMI cable is a likely suspect. Get yourself a heavy gauge (22-24 awg) high-speed (v1.3b or v1.4) HDMI cable (conventional, not RedMere) and run it across floor to test.
You could also get a couple of similar 10 ft ones and bring the components together somehow. Test the TVs HDMI port directly-into with a Blu-Ray player or DVR. Do similar testing with other devices and ports and find out what definitely works to start eliminating possible sources of problems.
post #2511 of 2524
I failed to mention I do use a Harmony 880 and the receiver is in standby mode, not totally powered off. It is sequenced and does come on before the other components with the Harmony. At this point, I don't see how it can be the cable when hooked directly to my DirecTV receiver, both audio and video come on immediately (taking the Onkyo totally out of the loop)?
post #2512 of 2524
About the Harmony and power-on sequence, good.
I was very specific about the tester cables. Not all HDMI cables are the same, or can handle the bandwidth (1080p video and HD-Audio). Over 10 ft. in length tends to start showing problems if lesser is used.
Direc-TV stream is likely lower bandwidth.
I was trying to think of a way for you to start testing stuff without spending much money and start eliminating items as proven working. If you have more money than time, buy a new AVR and have BestBuy come install it for you.
Edited by Tesla1856 - 4/6/13 at 11:20pm
post #2513 of 2524
I appreciate your time and insight Tesla. I'll contact the AV guy who does all the installs for this builder and came back to install my surround sound and calibrate/hook up everything. He comes highly recommended but he did mention he normally doesn't install Onkyo's and has very little experience with them (he mentioned when he buys a receiver for a customer he normally uses Yamaha. I'll ask him some specifics on the HDMI cable type. I may even get him to come back out and test the cable installed now and go from there.
post #2514 of 2524
The cable was just one of many possible things it could be. What you descibe is not normal (obviously) so something is broken somewhere.
Yes, a qualified AV tech should be able to fix it. Good Luck. I would be interested in hearing what the problem was ... knowing might come in handy one day (I currently support 5 systems for myself and family members).
post #2515 of 2524
Hi Tesla1856,
Here we go, It was the first time for me to use a forum this way.
So i think I am not the right one to ask.
I found the fixes, I think one of them where from you, and like to give something back.
Normally I am little divided about writing in forums.
Often people don't think of what they are writing, but they expect you to solve there problems without think themself.
Don't get my wrong, I like to help, but some ask you to solder......or ask how a cold soldering look like. Hmm......not so easy.
I think both the AVSforum and hifiengine looks a little better for me. that's why give back my info's.
Maybe some would like to see my fan solution?? easy and working, don't even get handwarm.
But you have to hear louder........;-) I should buy a quieter one.
Off topic: Do you like the design of the receiver....? Normally I have electronic from the broadcast/postproduction sector (not highend!!!), but some of the onkyo eletronic designs, seems a little spooky to me....I took my minutes to understand the concept of the powersupply to the display. And I don't know where they buy there resistors. A died resistor of 2.2 Ohm without being black? Never seen.!
But i understand that this all has the be cheap to sell it, and on the other hand, 7 poweramplifiers, a dolby decoder and a complete Video section with scaling for that price....
So like in all good forums, I posted a lot without giving any informations.....Yeaha..;-)
So everyone is now allowed to roast me........
Regards Nils
PS.: Some Informations:
HDMI sucks Depending on cable diameter, source and receiver, everything is possible....in my configuration it is running with a 10m cheap cable with the sr-607 and a benq-1070. In my oppinion quality of HDMi-cable is NOT depending on price. Outer diameter of the cable gives sometimes informations of the awg of the wires, thats more important than nice gold plated connectors (pins are always gold plated.....)
(it is like goldplated spdifcables.....;-)))
roast me
post #2516 of 2524
Hi Tesla1856,
Regards Nils
There are many of us that can read complex schematics and solder (properly) hole-thru and even SMT, so it's good for us to be able to chat somewhere. I like using my skills and recycling ... it's not always about saving money.
It's strange that Onkyo decided no fans. Obviously, it was because of the noise. But the heat is a killer and the 607 gets buring hot (as do other similar amps). It only takes a small fan to turn burning hot into luke-warm. I use Antec Veris AV Cooler. Even at max load/volume ... luke warm 607. Can't hear it at 6 feet away. Thought about adding thermo-control, but I think it would run 100% of the time anyway. On my Panasonic HE-200, I just added a PC case fan (attached to the top).
http://www.avsforum.com/t/1149887/panasonic-sa-he200-avr-overload
Sure, show your 607 fan mod. Maybe here if external. Maybe over at HifiEngine if internal?
Pretty sure, Onkyo saw the errors in their ways, and added fans to x09 series.
Yes, failed resistor is very un-common. Bad but not burnt ... really rare (never seen that either). You must be really good to find that. Yes, some of this stuff is under-built these days (really only barely working).
I used to be against HDMI also, but now (well, since 607 purchase years ago) I love it. Plus, it can do stuff like high-bandwidth signal Blu-Ray and much more. Cables are not magic and not all are the same. I know from past training and experience ... thicker cables/wires (lower gauge) is better and becomes more important as length increases ... even with digital signals like HDMI. Also, proper soldering/crimping/shielding, etc.
post #2517 of 2524
Hi Tesla,
Your are right, some people know what they are doing, so here we are
I will take a picture with my mounting.
But it is only a 80x80mm Fan and a piece of sheet metal.
The good thing was, that the universal port has 12V powersupply, so can take out that board, solder the two cables of the fan to it, thats it, really no rocket science.
I don't use the Universal port, so I think the 90mA from the Fan are really ok to handel....
Yes the place of the HDM is strange two, directly over the powersupply/heatsinks....seems to be, that they put the hdmi-board to an existing design....
If have seen many dead caps in the past on digibeta-Recorders, which are used in postproduction area, some they smell like a long dead fish....
And a good way to check if they are broken, is to use a hairdryer (drieer? I am from germany please be gracious to me..)
Make them warm, thats the way they are working again ( not al long time!!) than cool them down with cold spray to check wich of them is the weakest....
Yes i wondered about that resistor, because I remembered that some has a broken on the board on the transformer....so I didn't find thats normal.
I think the broke soldering will come from the rohs compatible Pb free soldering.
Yes normal one will break, but only when they have mechanical stress, and I promise, I never took out and shaked it, never!! And i didn't use it in my car, but that sounds like a good idea.....
Did your heart about hdbase-t 2k over a single cat 6 or 5 cable up to 100m (on full resolution).....I have one and it was quite amazing, just pluged it in with 45m patchcable (there was no longer!!)
And running! not cheap I bought the extender on a ebay china store, think it was about 120 euros....maybe 150 us Dolllars....
What I don't like on HDMI is the official 5m length restriction. this is nothing, and even when you don't have a projector, its not much.....thats what I am blaming. I have made VGA and Component connections up to 45m without equalisation....
Regards Nils
post #2518 of 2524
The issue at this point seems to be the Onkyo itself. I tried an HDMI signal booster per Onkyo support's suggestion and it did not help. I actually moved the receiver back to my original setup configuration (52" Samsung and DirecTV DVR) with a 4' HDMI cable (same setup I was using before we moved 6 months ago) and it's still taking approximately 10 minutes to come on. I guess another call to Onkyo will be in order tomorrow as I'm not sure what to do next.
post #2519 of 2524
1. I will take a picture with my mounting. But it is only a 80x80mm Fan and a piece of sheet metal.
2. The good thing was, that the universal port has 12V powersupply, so can take out that board, solder the two cables of the fan to it, thats it, really no rocket science.
3. Yes the place of the HDM is strange two, directly over the powersupply/heatsinks....seems to be, that they put the hdmi-board to an existing design....
4. If have seen many dead caps in the past on digibeta-Recorders, which are used in postproduction area, some they smell like a long dead fish....
5. And a good way to check if they are broken, is to use a hairdryer (drieer? I am from germany please be gracious to me..)
6. I think the broke soldering will come from the rohs compatible Pb free soldering.
7. Did your heart about hdbase-t 2k over a single cat 6 or 5 cable up to 100m (on full resolution).....I have one and it was quite amazing, just pluged it in with 45m patchcable (there was no longer!!)
Regards Nils
1. Would be cool to see pics. Inline temp control would be nice also. Seen cheap temp units at AV Cabinet Cooler sites. Did you find a nice quiet fan (I'm looking for future AV cooling needs).
2. Nice find. I don't use the Universal Port either, but I think that's where the iPod or HD-Radio attaches. I wonder if we can leave UP connected and tap 12v in parallel (since fan is under 100mA)?
3. Agreed. Onkyo 609 got a fan ... limited by volume, not temp controlled.
4. Seems to be industry problem. I find bulging and leaking chinese ones. Replace with good-name Japanese
5. Yes, I use cold-spray and my ESR-checker
6. I hate lead-free and think it causes problems over time. Hope they work it out or stop using it.
7. No, I did not. However, I use this for 1080p and HD-Audio (works perfect) "45ft 22AWG CL2 Standard Speed w/ Ethernet HDMI Cable" from MonoPrice. Actually, complete HDMI run is 57ft.
post #2520 of 2524
Agreed ... if those 4ft cables are good.
You could also try connecting the DVR HDMI directly to the TV ... that should check your HDMI Outputs and Inputs. Maybe the Onkyo got damaged in the move?
