Originally Posted by Jay_S
Initial observations: Opensolaris looks like it's a complete desktop package (includes gnome, open office, firefox3, very-ubuntu-like package management, etc.). I expected a command prompt.
*** My intended opensolaris/ZFS test bed is an ancient P3 dell optiplex. Will 2 dissimilar PATA drives be suffucuent for me to evaluate this setup? I think I read that ZFS can add just about anything to a pool, so I'm thinking the different drives won't pose a problem.
[EDIT]
OK, I found an older P4 system and a third PATA drive. This should make the experiment closer resemble my goal.
[EDIT]
That hardware should be fine. You *should* be able to install OpenSolaris without xserver and window managers. Or just have it installed just in case, but turned off. Open Solaris Storage has a lot of nice GUI's for managaing drive pools, etc.
Originally Posted by mythmaster
I'm sure there's a way to boot opensolaris to the command line after you get it set up in order to conserve resources. NX server runs on it, too.
+1 what mythmaster said
Keep us posted when you get your drive tomorrow!
Cheers,
Kermee
I didn't check to see which process was to blame. I'll double check tonight.
