AVS › AVS Forum › Audio › 2 Channel Audio › Parasound Model 2100 preamp owners thread
Parasound Model 2100 preamp owners thread - Page 22
post #631 of 648
Hey Bill,
I just purchased a Parasound 2100 which is 4 months old and in new condition.I loved yours when I first listened to your system.You will have to give me all the info on using it the correct way.
Bruce
post #632 of 648
Hey Bill,
Thanks for your help on the SPLITTER.
Bruce
post #633 of 648
So I read quite a few reviews on the parasound zdac and the comments seem very positive/encouraging! I imagine the DAC internals from this that are also used in their new CD1 will be used in the upcoming P5 pre. If so, it might be a great combo and hopefully an improvement over my 2100 and PS DAC3 setup.
post #634 of 648
Originally Posted by voigtskins View Post
Hey Bill,
Bruce
Bruce,
My pleasure smile.gif. I'm glad I could help out.
Brandon,
I wish I could find the email that Richard from Parasound sent me regarding the P5. If I recall Richard said the DAC in the P5 was as good or better than the Zdac. You could try emailing Parasound with any questions you have. I'm sure Richard would reply and would have plenty of information on the P5.
Bill
post #635 of 648
Thanks Bill.
I can just wait and see what the P5 will entail:)
Should be interesting!
post #636 of 648
I wonder how the zDAC compares to the Emotiva DAC? I am looking for a new DAC & possibly a Pre-amp. I like the fact that the Emo DAC can be used without a pre-amp.
I would like to be able to connect a DAC to my computer, then connect the DAC to my AVR so that I can listen to my high Rez downloads.
post #637 of 648
Hi Everyone,
I'm considering a P2100 and found this thread while searching for some info. I'd like to know more about the phono stage, but there is very little information on the Parasound site or in the user manual. Does anyone here know the specs for the MM and MC gain, input sensitivity, impedance, etc?
Their site says "1 input pair can be switched for MM or MC phono cartridge with correct input impedance", but it doesn't say what the impedance is. I assume it's 47kOhm for MM, but what about MC?
I did read some posts earlier that the phono stage is a weak point on the P2100, but I'd still like to know the specs before making my decision.
Thanks very much.
Edited by Mescalero - 9/16/13 at 6:23pm
post #638 of 648
I'm selling mine soon too:). Did you grab the P5? Mine should be arriving soon!
post #639 of 648
My 2100 has been sold. Thanks.
Edited by Nuance - 11/15/13 at 11:43am
post #640 of 648
It has not changed since 2009!
post #641 of 648
Actually there has been one nice change. The volume control was changed to allow much finer increment level changes when the remote is used. I'm not sure when this change was made but the 2100 I currently own has the upgraded volume control. It makes a big difference as the volume control on older 2100s I've owned was in much larger increments. Also the remote itself was upgraded with a slightly different shape and button layout.
Bill
post #642 of 648
Originally Posted by Bill Mac View PostActually there has been one nice change. The volume control was changed to allow much finer increment level changes when the remote is used. I'm not sure when this change was made but the 2100 I currently own has the upgraded volume control. It makes a big difference as the volume control on older 2100s I've owned was in much larger increments. Also the remote itself was upgraded with a slightly different shape and button layout  Bill
There is no volume control on this it is an amplifier?
post #643 of 648
The 2100 is a stereo preamplifier so it has a volume control.
http://www.parasound.com/nc/2100.php
Bill
post #644 of 648
The 2100 is a stereo preamplifier so it has a volume control. http://www.parasound.com/nc/2100.php. Bill
My bad this is what I was talking about http://www.parasound.com/halo/a21.php
post #645 of 648
Not a problem. You were close just off a few zeros which I usually am as well wink.gif.
Bill
post #646 of 648
Ordered a 2100 and Zdac yesterday.
Curious to determine whether they are an improvement over my current Cambridge C500 pre and Music Hall DAC 25.2 (current DAC) and an Emotiva DC-1 DAC (in 30 evaluation period, but sounds better than the Music Hall, IMO).
Per emails from Parasound, the 2100 and Zdac combo should sound better than the P5 for digital sources, due to the superiority of the Zdac over the P5’s internal DAC. They do not use the same DAC design.
post #647 of 648
Howdy. I'm new to this forum.
I received my 2100 a few weeks ago. I have it in a conventional 2 channel system. It's exactly what I wanted: sub management; tone controls for the occasional times I want to use them; multiple inputs; remote; high pass output for some full range drivers I will build in the future. I won't need the phono for now so any short coming it has is not a concern.
This is paired with a ST-35 I built a few years ago. It has added greater low end and overall improved accuracy to what was a pretty good system (Infinity RSb). I have a Polk sub but have not found the need to use it.
Overall I'm very pleased.
post #648 of 648
Congrats! The 2100 is a solid full-featured preamplifier.
