Minor Update... Finally set up my lighting control... I was a bit worried by some of the older posts about poor Insteon quality... If my experience is any indication they have all of those early problems worked out.
I sprang for one of Universial Devices' ISY-99i/IR PROs and I will say that it made Scene Setup dead easy... and I am already spoiled by the setup of an "all-off" button as I leave the basement. It also allows control through a browser even has an iPhone app...
Also set up my Harmony One Universal Remote, everything is working well with one little snag. Projector Control is great pointing the universal (or projector remote) at the screen) but for the other components I need to point the remote off to the left, this has about a 25% chance of not picking up the projector when I send the "Activity" command to the other components. All the universal needs to do is turn on the projector...
Any ideas for a cheap fix??? IR blaster, extender, repeater? If it is a hard wired solution it would need to extend about 35 ft from the cabinet to the projector...
Over all I am incredibly happy with my setup... It has worked great for everything I have thrown at it... Gaming and Netflix with the xbox, Gaming and Blu-Rays with the PS3, Gaming, Hulu and surfing with the new HTPC.... Noticing a theme yet?
I have even flipped on the Satellite Receiver a couple times to watch TV...
635 hrs on the lamp so far...
Oh I almost forgot I have the DVD Case Doors built with a second coat of stain applied last night... Should try hanging and trimming this weekend...
