AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › BIC Acoustech H200 Subwoofer (AKA PL-200)
BIC Acoustech H200 Subwoofer (AKA PL-200) - Page 10
post #271 of 1304
Originally Posted by 42Plasmaman View Post
You might want to look in to an HSU sub.
People have been able to run their subs in overdamped mode and using the audassy EQ(assuming your receiver has this feature) to get a flat response of the freq's through the subs.
http://forum.hsuresearch.com/showthr...5017#post55017
*HSU also has a 30 day money back guarantee - shipping.
Also, does your receiver have a manual adjustment EQ for the subwoofer?
I would want a matched sub, and no my receiver doesn't have EQ.
post #272 of 1304
Damn these BIC Acoustech PL-200 look amazing and can be found on Ebay. I guess since I am waiting for my Onkyo TX-SR608, I should think about ditching my cheap Sony Sa-w3000 subs for these; yes I had a budget system made up of Sony. I think I remember reading some users paired these subs with some Polk Audio speakers, anyone use anything else?
dja2k
post #273 of 1304
If I am reading correctly, the consensus is that if you have the cash, then for $70 more the HSU STF2 is a better sub than the PL-200. Is that correct?
post #274 of 1304
Since better is subjective, I don't see how that could be the consensus, nor did I gather that being said from this thread. STF2 is probably better for music though.
post #275 of 1304
This is a great thread. I read most every post and decided to order the PL-200 tonight. Got it for $279 and that seems like an amazing price for what you get. Considered a A2-300 but at over $400 it didn't seem like it was worth the extra cost.
I'll be replacing my 10 year old Cerwin Vega HT-S10 with is a 10" down firing sub with 100W, it has served me well but I upgraded all my other speakers almost 2 years ago and my AV receiver last year.
The PL-200 will be used with my Yamaha RX-V3900 AV Reciever, Energy C-500 front towers, Energy C-C100 center channel, and Energy C-200 bookshelf rears.
I do 90% gaming/movies on this setup and 10% music at most. So this seemed like the best sub for me.
Hopefully I have no issues with it and it does what I'm hoping it'll do. I missed out on a clearance Energy ESW-V10 a few months ago and think this is a great alternative, and it is cheaper too.
post #276 of 1304
Good choice. Do let us know if us owners can be of any assistance.
post #277 of 1304
You won't be sorry. Excellent sub for the price, especially for movies and games.
post #278 of 1304
So im stuck between the Bic 100 and 200, price being the main factor. The problem with Bic is that I cant find any Canadian Vendors... so the duty/ brokerage kills me! That being said Overtock.com has the Bic acoustech h100 for approx $330cdn all-in (i.e taxes, brokerage, shipping). Sound Distributors has the Bic PL200 for about $460 cdn all-in. The question I have is the 200 worth the extra $130?? First post.... and I can't believe how much I've learned since this morning! WOW! thx.
post #279 of 1304
would this be a good match for Mirage Nanosat speakers? Looking for a sub with good upper end (100-120hz) response, but can still get deep since the nanosats cut out early due to size.
post #280 of 1304
can i ask all owners opinions on maximum size room this unit might work in? i have large room with only room for one sub due to layout. it seems this one would be limited to a room around 2500 cubic feet or so.
post #281 of 1304
Do you guys think a pair of these PL-200's will sound fine with a Polk Audio setup with Monitor 50's as Front, 4 Monitor 30's as Rear, and a Monitor Series CS2 for Center Channel.
dja2k
post #282 of 1304
dja2k
What kind of receiver and does it have EQ capabilities for the sub(20hz, 40hz, 60hz, 80hz) ?
The biggest issue with these budget subs is getting a flat response out of them. You will get low end boom without a doubt, which people perceive as a "good" subwoofer but then you get dead spots in certain frequencies.
A good subwoofer is more than shaking the walls with 20hz. It's about proper low end response throughout 80-20hz.
This is where an EQ comes in to play to level out the frequencies so you get good consistant bass and LFE.
Audyssey does a great job EQing if it's built in to your receiver.
Sometimes, an EQ can't fix this either.
post #283 of 1304
dja2k
I think it would be OK. I have Monitor 60's, and I'm only comfortable running the crossover for them at around 60hz, but really the PL-200 in my situation seems to do really well with really low frequencies, anything below 60 or so, but above 60 it really seems to fall flat. So I am left with the sub doing all of the bass work, and the fronts aren't really going low enough to really fill in that ~60 range, +/- 10hz. It could, and likely is more related to my room though. EQ on my receiver would be a HUGE help, like 42Plasmaman said. To me EQ is almost a requirement. How I ended up with a receiver without it I will never know. 2 PL-200's might be better, depends on the situation. I say go for it.
post #284 of 1304
I just pre-ordered an Onkyo 608 and will probably be leaning towards two PL-200 Subs and Polk audio for the rest of the setup. I haven't purchased the subs nor the other speakers yet, still shopping around. My old setup was a Sony receiver with all Sony speakers, so this is a big jump. For the price and sound, Polk Audio is good for me, unless I find something around the same price range. Man didn't think audio stuff can get so expensive when you want a good setup.
dja2k
post #285 of 1304
my room is roughly 31x16x8 and I have my sub set at the 1 o'clock position and it sounds pretty damn good.I have all my speakers set to 40hz on my receiver and they can hadle the lows with no problem.The sub rattles all the windows along with some of the furniture.
by the way I have a Yamaha RX-V663 and an infinity Primus set up consisting of 2-P362's 2-P152's and the PC350 for the center if anyone was wondering.
post #286 of 1304
How is the LFE channel set up on the receiver? As far as dB +/-? I have mine set to +8dB and anything over about 11:30 on my volume knob scares me. Sounds like it's going to come apart, but maybe it won't and would do fine set that high. I've never had a sub of this scale before, only smaller, cheaper ones.
Also, wouldn't it be less "stressful" to the amp to have the receiver set higher, and the actual volume on the amp/sub turned lower?
post #287 of 1304
Would you say that a pair of Monitor 70's paired with only 1 PL-200 would be better than the Monitor 50's and the 2 PL-200 subs I was first thinking of getting?
dja2k
post #288 of 1304
dja2k
That's a tough one. I haven't heard the 70's in person, nor have I heard the difference in 1 PL-200 vs. 2, but I would imagine that they both would be fine. The 70's would probably allow much more full bass, with a little less work for the sub, but at the same time, the little speakers on the 50's and 60's seem to handle some bass fairly well, and 2 PL-200 would probably give a more full sound with a higher SPL overall. Tough decision.
post #289 of 1304
Don't know what to choice either, but maybe I should start thinking of my surroundings. Maybe getting the two Monitor 70's is a better choice and that way I can turn off the sub for normal low volume viewing when I don't want to make the whole room rattle.
dja2k
post #290 of 1304
Hey are all of you ordering the PL-200 from Ebay or from where?
dja2k
post #291 of 1304
I have used sounddistributors, got it yesterday... I will post a little review soon, now I'm into disasembling this little puppy...
post #292 of 1304
Pictures Pictures!
post #293 of 1304
I'm new member, so I need to have couple(3?) posts before sending any picture urls... almost done!
post #294 of 1304
Pl-200 disasembled:
post #295 of 1304
My woofer isn't really platinum... it is rather light copper color...
post #296 of 1304
My woofer isn't really platinum... are they started to use chipper components for pl-200?
Are you saying yours doesn't look like that? Crap and I was going to order two of these, but not if they are putting cheaper components in there.
dja2k
post #297 of 1304
They are using the same parts as they always have. They are champagne in color, not platinum.
post #298 of 1304
Would the Audyssey 2EQ do a good job of eq'ing this sub? I've got an Onkyo tx-sr606 wich only has 2EQ. I looked on the Audyssey web site and it says "it does not apply a filter to the subwoofers". So I guess it just sets a crossover and level???
http://www.audyssey.com/technology/m...solutions.html
post #299 of 1304
Pl-200 disasembled:
I wonder if covering that 1 naked wall (floor) would help any...
And for the record mine is the exact same color.
post #300 of 1304
The LFE level goes from -20 to 0 which is where I have it at.I tried the crossover set at 120hz and it sounds better.Shouldnt it be the other way around?
