Originally Posted by
speedking
You are right, there are no "good" options over the 65" size. Although I always mention the FP option to people who have a greater distance to their display, it's not an easy setup.
You're wrong!
Outside of FP, there are plenty of great options - if you can live with one or two limitations regarding vertical viewing angles and non wall-mountability.
RPs
Samsungs 750 DLP series received Cnets Editor's choice and I can personally attest to it's PQ being very comparable to Panasonic's 58" 800u in terms of sharpness, vibrancy, black levels and and color accuracy.
And is bulb/colorwheel/noise-less.
Panasonic's only advantages are better viewing angles, uniformity and mountability ALL of which are negligible in a proper sitting environment
Mitsubishi makes great DLPs too with one coming out at 83 or so inches.
Their Laservue DLP gives even the mighty Pioneer Kuro a serious spanking. Also bulb/colorwheel/noise-less.
All of which has nearly perfect motion resolution, no blur and for the most part, the best value in size/quality.
