AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Odd HD-A1 issue
Odd HD-A1 issue
post #1 of 4
I'm having a weird issue with my HD-A1. It is hooked up via HDMI to my Pioneer VSX-01 receiver. If I turn the receiver and tv on first, the A1 boots up normally. If I turn it on first, it sticks on "Welcome" and I have to hold the power button down for 5 seconds to re-boot it. Is it just looking for the HDMI handshake, or am I looking at the early stages of a failure?
post #2 of 4
Try pressing the V. Output button on the remote (the player's display should say HDMI in the middle-top of the screen) to make sure you're actually in HDMI.
post #3 of 4
if you're running older firmware it will do this, try updating to 4.0.
post #4 of 4
I did an initialization and cleared persistant memory. Firmware is at 4.0. I think this has something to do with my receiver. Before I bought the new receiver, the A1 was hooked directly up to my TV. Now, it goes through the receiver first. I believe there is a setting on the VSX-01 that allows the receiver to send HDMI signals to the television even when the unit is off. I'm going to see if that helps.
  Back to Forum: HD DVD Players
