AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › WD TV Prerelease 1.02.04 is out
WD TV Prerelease 1.02.04 is out - Page 12
post #331 of 415
Originally Posted by techflaws View Post
I'Ve read on one of the larger sub forums (no anime) that there's a 50/2 rule.
2 lines max per item and 50 chars max since most standalones have problems with more and word wrapping can look ugly.
I go for the 70 max per screen, 45 max per line as i found it was the best solution for a dvd/xvid player i bought in 2003, a crappy chinese one that still works and that i use to see original dvds and films archived on dvd
post #332 of 415
I don't disconnect the wd-tv, and it still shows the tumbnails, even the new ones
post #333 of 415
Originally Posted by Offlime View Post
Do you have a proof? Did you test it over HDMI or optical or both?
I have proof.
I have recorded the output signal (from optical) and compared on a PC a and the output from the WDTV is definitely amplified, which causes the mentioned clipping.
post #334 of 415
Originally Posted by hiendas View Post
... the WD TV suffers from what is known as "waveform clipping"...
Please post hard evidence (oscilloscope screens?). Im sure that WD can fix that...
post #335 of 415
Originally Posted by indusbreed View Post
Anyone care to share the program/process to lower the Reference frames. I have some movies with Ref frames as high as 18. I want to lower it down to 4/5
IB
18 can't be, since 16 is the maximum number of reference frames.
There is no "program to share", you need to recode the video stream with your prefered encoding / converting solution, resulting in an inevitable loss of quality. If you own the Blu-ray / HDDVD / whatever source, you better rip it again.
post #336 of 415
Another BUG to report, I think:
I have an mkv with a dozen built-in subtitles + an external subtitle in .srt format in my own language. WDTV doesn't see the external subtitle which consequently does not show while cycling through available subtitles...
sorry if this was reported before, but I don't seem to remember it was...
post #337 of 415
Could there be a max number of subtitles for each file, say, 16, and you've got 16 inside and one (the 17th) outside?
post #338 of 415
Originally Posted by tkwok View Post
i'm not sure if this has been mentioned, but about half of the movies on my hard drive is not updating with the new thumbnails jpg. Has anyone else experience this? if so, how did you force the WDTV to update the thumbnails?
thanks
I have had success getting the thumbnail images to "update" by resetting the WD to original factory settings from the configuration menu. Seems to work quicker than deleting the folder from the HD.
post #339 of 415
I am wondering, how many times should I repeat myself by reporting again and again that the WD TV suffers from what is known as "waveform clipping" .
Do you have any details to back up your claim? Describe your audio chain. What is your source material? All file "clipping", or just some? What settings do you use on your playback equipment?
post #340 of 415
I have the same problem so I'll try to answer:
Tested on optical out, I've grabbed a CD to wav and played the wav on the WDTV, the playback was recorded on a iRiver H-140 (via optical of course).
Then I've compared the recording and the original wav on a PC and the recording is amplified and there is clipping in peaks.
Is it enough information or do you need more?
post #341 of 415
Hi & thanks for your reply. I'm not very familiar with the iRiver unit you have , so I'll assume that it doesn't add any gain to the inputted source file. I too am very interested in the audio side of this box, as I'm hoping to use it as my main source for music playing in my system. On my wishlist is gapless playback and maybe even simple crossfading .
Do you hear this clipping on ALL music tracks you play or just certain ones?
This is the first I have read about this issue, and I haven't experienced it yet myself (still on first official upgrade FW). Most of my music files are FLACs, and of course some mp3s & oggs. I have found that many mp3s of CDs , when analyzed with MP3 Gain, tend to be way over compressed (99% & over) which will add distortion upon playback. Though obviously your source is from the original CD.
Hopefully we can here something on this topic from one of the WD guys.
post #342 of 415
i'd like to know if the clipping affects video playback?
also, to the guy with 13 different subtitles, try taking some out with mkvmerge, 13 is excessive and no-one would need that many subtitles!
post #343 of 415
MKV supports up to 16, so why not have 13? You might not need that many but he does, and it should be fixed if it's a bug in 1.02.04.
-Mod
post #344 of 415
Your assumption is right, I've tested it with the CD I grabbed the wav from in a CD Player connected via optical to the iRiver and the recording is a exact match with the grabbed wav.
I was also hoping to use it as my main source for music playing in my system, but in this state it is not good, not to mention the downsampling of 24/96k FLAC to 48k ...
When I have time I'll do some more tests with flac, ogg, mp3 ...
I hear the clipping only on some tracks with high peaks.
It was an original CD.
post #345 of 415
-Mod
Most people I know only speak one language and some maybe two or three.
Why would you rip/encode with so many different tracks? I don't get it...
post #346 of 415
Since I updated the firmware my wd hdtv device won't read my Seagate FreeAgent HDD or USB memory stick. Is it possible for me to revert back to 1.01.02 firmware again (that is if I can get it to read a device)
Hope I can get help
Thanks guys
post #347 of 415
Let me tell you about my friend named "Rosetta Stone"...
post #348 of 415
really, did you search at all? This info is at least 20x posted on the forum
more here: http://wdtv.wetpaint.com/page/Firmware
post #349 of 415
What's the difference between:
1080p/23Hz and 1080p/24Hz?
Which one should i pick for 23.976 videos? (mkv and xvid)
post #350 of 415
more here:
thanks
post #351 of 415
Here's some "hard" evidence:
On the right side is the original and on the left side is the recorded signal from the optical output from the WDTV.
It is 1kHz sinus tone cca 20 sec log with volume steps 0dB, -1dB, -2dB, -3dB, -4dB, -5dB, -6dB
From the picture you can clearly see that the output is amplified by +1dB, which causes clipping in records with peaks over -1dB.
I've also analyzed the max. volume of a bunch of original CDs, most of them have peaks over -1dB, close to 0dB -> clipping if grabbed and played through the WDTV
post #352 of 415
Hello,
i´m a 15 year old italian boy and my english is not so good, sorry.
My problem...I run an AVI file then runs the sound but the picture comes 40 seconds later. with the old 1.01.02 firmware was not a problem. Can someone help me...thanks.
greetings from italy
vincento
post #353 of 415
BOTH resolution settings do not work properly right at the moment when watching 23.976 videos
23Hz sets the resolution to Standard Definiton (*bug) and there is exactly 1 studdering in every 40 seconds when using the 24Hz setting while watching 23.976 videos.
The correct one for 23.976 videos would be the 23Hz setting (=^ 23.976 Hz = 23.976 frames per second) setting, but since it's broken use the 24Hz setting! (= 24.000 frames per second, very rare)
post #354 of 415
Originally Posted by vinceac View Post
Hello,
vincento
Ciao, Vincento!
Use a program called mediainfo to gather information about your file and post it here, prego!
post #355 of 415
Regarding idx/sub subs, i can confirm that the last subtitle is not showing up with 1.02.04
post #356 of 415
IB
Re-encode the video using your prefered encoder, I use MeGUI, but Staxrip, and Ripbot work ok too.
post #357 of 415
I have reported the audio clipping issue a long time ago, also the 96KHz to 48KHz downsampling issue.
The replay gain is fixed and you cannot do anything about it.
Don't trust your ears, trust me !
post #358 of 415
Exactly !!!
You can also record a sinewave at 0dB and observe the o/p on an oscilloscope
post #359 of 415
SInce it doesnt look like anyone asked did you name the srt file correctly? It should be in the following format:
Movie.mkv
Movie.srt OR
Movie.mkv
Movie.language.srt (where language is the language the srt file is in)
THe Srt file will show as the 1st subtitle track (at least thats how it works on mine).
post #360 of 415
Tested this , working fine
General
Complete name : F:\\NhaNC3 Movies\\AC3\\Blade.II.2002.m-HD.x264-AC3.mkv
Format : Matroska
File size : 1.63 GiB
Duration : 1h 52mn
Overall bit rate : 2 085 Kbps
Movie name : Blade.II.2002.m-HD.x264-AsCo
Encoded date : UTC 2009-04-14 20:51:30
Writing application : mkvmerge v2.6.0 ('Kelly watch the Stars') built on Mar 24 2009 15:23:17
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 10 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 52mn
Bit rate : 1 546 Kbps
Nominal bit rate : 1 727 Kbps
Width : 832 pixels
Height : 528 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.141
Writing library : x264 core 60 r895M 16b8f79
Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / rdcmp=psy / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1727 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 52mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Language : English
