Originally Posted by
jonkrav
Can anyone tell me as i cant seem to find an answer... (and its related to this thread because of new 24hz update :P)
Whats the difference between 24hz and 60hz and why do people prefer 24hz?
Also how can i tell if 24hz is supported by my tv? I tried it and its fine and no stutter from previous versions but not sure if i should be running it or not?
FYI i have a samsung le40a656 please answer me somebody!
Your TV does support 1080p/24Hz, I know because a friend of mine has the same model.
I have a different Samsung model, but they all are very similar as far as the setup is concerned. Set the WD TV-HD to 1080p/24, and press 'Info' on your Samsung remote. It should show you that it is running at 1080p/24. If your TV supports 100Hz (I think it does, not 100% sure though), turn it off in the setup also while you are at it.
People (cineastes in particular) prefer the 24Hz (23.976Hz rather), because that's the
native frame rate of movies, a necessity for the authentic 'film look'. If you play them back at 60Hz, they look more like videos, or TV for that matter. That authentic look is lost.
