AVS › AVS Forum › Audio › Speakers › theater research speakers
post #1 of 8
I have a chance to get a whole home theater speaker package for 500. The speakers Theater Research TR-1610 and TR-1611 Series. I don't know anything about these speakers was hoping for some input. Are these quality speakers or are they junk? are they worth the $500? are they worth more? please any help would be grand as I have no idea what i'm getting into
post #2 of 8
I think they're white van.
post #3 of 8
White Van Speakers! AAAAHHHH! RUN!
post #4 of 8
so whats this mean are they any good or should I just steer away? come on fellas like I said I didn't know what I was getting into. A little more input would be great!!
post #5 of 8
Read the two links provided above!
Yes, you should steer away.
post #6 of 8
DON'T DO IT!!! They are junk speakers. Go to Best Buy, Crutchfield, or a local Audio Video store.
post #7 of 8
Theater Research is Junk!
If you've got $500 for a system, go with Energy!
http://www.wwstereo.com/#/ecommerce/..._84__0_0_0_-1/
And if you need a system with a sub, look at this one...
You get a complete system with 5 years mfrs warranty from an authorized dealer.
post #8 of 8
right on I appreciate the help I'm glad I never went to check them speakers out I probably would have blew one or all of them while running some power through them
  Back to Forum: Speakers
