AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › which one?
which one?
post #1 of 12
Need one for the bedroom. Nothing fancy. Getting at Sam's due to their non-restrictive return policy. Options:
Toshiba 40RV52 $748 1080/60
Vizio V042LF $797 1080/60
JVC TL 42PM30 $798 1080/60 Similar if not same as LT-42P300. This one is new and not on their web site yet . Has ipod teledoc, but not sure we'd use it.
Since all in same price range, looking for best value.
Sam's also has a Panasonic Plasma TC-42PX14 for $698.
Thanks for any help
post #2 of 12
Since none of them are high quality models, I'd get the one that looks best to you.
post #3 of 12
Price discussion aren't allowed on this forum
post #4 of 12
Yeah, I normally would have said that also, but since Sam's is the only place he's looking, I thought I'd let it slide. My bad.
post #5 of 12
ooops. sorry about the price thing. Yeah, they all seem about the same so was more concerned if a JVC was more reliable than Vizo, etc.
thanks
post #6 of 12
the toshiba, is the best out of the ones you list.
post #7 of 12
plasma for the win
post #8 of 12
would any of these have better SD or all about the same?
post #9 of 12
I don't there there would be much of a difference with any of them [IMG]http://www.entertainment-place.info/smile/img/2464/*************************[/IMG]
post #10 of 12
Panasonic Plasma FTW as well. [IMG]http://www.***********************/track/img/3358/m09d0317xktz/2.gif[/IMG] It's a good brand and a personal favorite of mine.
post #11 of 12
I've been shopping hard the last two weeks, and really wanted to buy at Sams for the same great return policy. I'd considered that Toshiba and a similar 40" Sony LCD, but really thought I wanted a plasma. So I've been kind of stuck.
Then I just saw the Panny plasma on the Sams site. I check their site almost every day, and just saw this model appear. Unless there's something I don't like about it when I see it in person (is this different from the X1 I've seen at Sears?), I'll probably pick it up.
Sometimes things *do* work out perfectly.
BTW, to gtpainter: I'm very much a novice on the new TVs, but someone was telling me in another thread that Panasonic handles SD very well. That's important to me as well because I still watch a lot of SD.
post #12 of 12
I am stuck between these two as well, I have a panny love it ... but this one is 720P...
I know notyhing about JVC but looked great to me, only 6500:1 contrast ratio though....
good luck!
