This will serve as the official RS-MaxxMudd V2 updated mix thread...
This thread will serve as the official RS-MaxxMudd V.2 Mix... it owes is ancestory to MMudd and this MaxxMudd thread before it:
the original RS-MaxxMudd thread... http://www.avsforum.com/avs-vb/showt...ht=rs+maxxmudd
RS-MaxxMudd v.2
RS-MaxxMudd Retro v.2
(darkest and highest gain of the rs-maxxmudd mixes, note the amount of SILVER in the mix)
20 oz Liquitex Basics Silver Metallic
8 oz Delta Pearl Finish #02601
6 oz Behr 1850 UPW Flat
12 oz Minwax PolyAcrylic Satin Finish
15 oz distilled/tap water**
RS-MaxxMudd v.2(for low to moderate ambient light)
16 oz. Liquitex Basics Silver
12 oz. Delta Pearl Finish #02601
8 oz. Behr 1850 UPW flat
12 oz. Minwax Polycrylic - Satin finish
15 oz. distilled/tap water**
RS-MaxxMudd HGC v.2
(for high gain contrast bat caves ht's)
20 oz. Delta Pearl Metallic #02601
12 oz. Liquitex Basics Silver
9 oz. Behr UPW flat
RS-MaxxMudd LL v.2(for lower lumen pj's and controlled light home theaters)
8 oz. Liquitex Basics Silver
12 oz. UPW flat
this is the only mix of the rs-maxxmudd family that can be rolled
The Liquitex Basics Silver is found at Michaels, Hobby Lobby, or Dick Blicks. (Artist's paint area)
The Delta Pearl Finish is also found at Michaels, Hobby Lobby, or Dick Blicks. (Craft paint area)
The Behr 1850 and Minwax Polycryic is found at Home Depot, Menards, Lowe's, Walmart, Ace.
** The suggested water amounts are best practices based upon Wagner CS DD and Plus models and also the Graco sprayer.
For the original Wagner CS spray, more water may have to be added... do so in 2oz increments
HISTORY: Formerly known as RS-MMMaxx... this mix was built from the foundations of the original MMudd and MMudd-SE
After a month of PM's with MM... RS-MMMaxx was introduced to AVS through the MMudd / SE thread...
http://www.avsforum.com/avs-vb/showp...&postcount=271
Here you will find the very first formula for RS-MMMaxx
http://www.avsforum.com/avs-vb/showp...&postcount=284
Here is MM introducing RS-MMMaxx Light Fusion for the very 1st time...
EVOLUTION of MMudd / SE ... to RS-MMMaxx ... to RS-MaxxMudd
- the Behr UPW component remains intact.
- the Delta Pearl replaced the Behr WOP... as it is a brighter white and contained more metallics. (Behr later retired WOP)
- the Behr Faux Silver Metallic was replaced by a Delta Pearl that has less 'lamp black' within it's silver base.
- Aug. '05, the concensous was... adding 3 to 4 oz to a QT of UPW of any silver or aluminum metallic resulted in crushed colors and white levels.
- using delta's silver metallic allowed the use of 2x,3x,4x the metallic ever successfully used before.
- Aug. '05, the concensous was... any amount of poly added to a paint mix was very limited...or simply unsuccessful.
- Minwax Polyacrylic - replaced the Behr Deep Base and proved the above poly misconception to be untrue.
- Polyacrylic is both a translucent agent for the metallics (for Light Fusion/Mirrors) & a viscosity agent for spraying, leveling, & increased work time.
- Behr's Deep Base was eliminated due it's nature to turn 'brown' when dried.
- Folk Art Champagne Metallic (Delta Pale Gold was retired)... helps to remove any slight blue push of the metallics and return warmth to flesh tones.
Screen Substrates:
TWH - Thrifty White Hardboard (found at Home Depot):
- tutorial for spraying TWH... http://www.avsforum.com/avs-vb/showt...775&highlight=
Application Methods:
Wagner Control Spray:
- tutorial... http://www.avsforum.com/avs-vb/showt...078&highlight=
RS-MaxxMudd v.2
RS-MaxxMudd HGC v.2
9 oz. Behr UPW flat
12 oz. UPW flat
Screen Substrates:
SUCCESS
