Originally Posted by
toby10
Just don't use that feature. No HDTV "depends" on internet access, it's just an added feature.
I haven't looked at the HDTV market in a while but my two HDTV's do indeed have an actual OFF button. Such buttons are rarely used by consumers so the mfr's may not even bother with them anymore. People want to use their remotes (IR or BT) to turn ON their devices so the device cannot be truly "OFF" if you want it to see and respond to the remote command to turn ON.
Might also be that the firmware in the newer TV's is volatile, meaning the settings etc... may get erased if the TV does not have power for an extended period of time. Just a guess though.
Even when the off button is used (much like my STB) it's on a stanby mode, only way to completely take power off is by unplugging.
Case in point, I picked up a less expensive Blue Ray player for the parents last holiday season, the first thing it wanted when powering up was 'Need to connect to internet'. I simply did not want anything that complicated, I don't want U-Toob, Voodo, Netflix (all associated with some sort of 'EZ monthly' fee of course). I simply wanted something that would play a Blu Ray Disc. That's why I went out & searched for an old stock Blu ray 1.1 for myself.
Now as I may be needing a set soon myself I shudder to think of what features I'll have to buy into that will only confuse the operation. When I turn on my old Phillips it now defaults to CC1 on, a feature I seldom use. Personally I really hate gadgets & extras, because 1) they hinder with normal operation, 2) they break, & are expensive to fix.
