Originally Posted by
nymets7588
Dont know much about projectors. Is a Sanyo PLV-Z2000 with about 500hrs on the lamp for 1550 a good price? a simple yes or no would be great thanks
After rebates, I bought mine new for $ 1750 last year. A new bulb will run you about $ 250, so I'd say the projector is worth the cash if they threw in a new bulb. Otherwise, I wouldn't pay more than $1400 for it. The current bulb will most likely last at least another 500-1000 hours.
It's a very good projector and is better than Sanyo's current budget 1080P since it has inorganic panels.
