Originally Posted by CRussell0300
I see on Garmin's website that you can download custom vehicle icons for some of their GPS units...
Can anyone shed some light on how to load these onto the DNX6140? Or does anyone even know if that is possible?
EDIT:
A friend of a friend installed my DNX6140 today in my '07 Ford Escape. It took about 2.5 hours, we ran into a few snags, but those were problems with the the car, not the DNX6140. Afterward, I spent an hour changing a bunch of settings, programming radio stations, and playing with the unit. I tested out a bunch of the features, and I'm extremely happy with it!
For those who are curious, the bluetooth paired seamlessly with my iPhone 3G, address book and all - no problems whatsoever. I made some test calls, they came in clear for me, and the people on the other end said they heard me just fine, but I sounded "a little funny" - like normal speakerphones. I have the mic placed right on my steering wheel column. I had no problems with dropping the signal or anything like that.
Still not sure how to load the custom vehicle choices onto the GPS... And does anyone know how to change the startup screen to a custom image? There are instructions in the manual for a custom background, but nothing as far as I can tell for a custom startup screen... I have heard that it can be done, though.
Woohoo!
EDIT:
Woohoo!
Do you have 3.0 software on the iPhone? I am having 2 issues using this unit with the iPhone:
When I have my iPhone playing on the iPod Source, and I attempt to make a telephone call using Voice Recognition the music gets transferred into the call and I can hear the music and the person. I should only be able to hear the person as the music should fade out.
I believe this is related to 2 things.
1. The phone and ipod source are coming from the same device, the iPhone.
2. iPhone Software 3.0 recently released enables Stereo Bluetooth whereas iPhone never had this before.
I feel I would not be the only one experiencing this problem and infact anyone using this unit with an iPhone would most likely be in a very similar situation.
Can you please try this? It would be a huge help in my troubleshooting as it is hard to find someone with an iPhone 3G and the same unit.
The other problem is if I leave my iPhone plugged in and start the car, the music will play for about 5 seconds, and i will be forced to unplug and replug in the iphone for the ipod music source to begin playing music again. Can you also try this?
