Originally Posted by
goondog
This thread rocks!! Im so glad i stumbled onto it.
We just bought a (please be kind) toyota sienna with a jbl system/no nav and wanted to do a kenwood or pioneer setup immediately. Based on the info here it sounds like i should spend a little more and go kenwood.
Im planning to add an overhead dvd unit by audiovox.
Does anyone know if an iphone/ipod with video can be played on the overhead unit or just on the kenwood?
The boss wants backup cam, sirius and iphone hooked up asap.
Do most run the iphone/ipod connector to a central console or to some mount?
Also is there a big difference b/w this and the next model up 7140 besides the extra 1"? seems like $500 for that increase is steep.
thanks for all the info and help!
You can play music and video from your iPod on the unit. You can then hook up other monitors via the AV output on the head unit.
I bought my 6140 from Sonic Electronix for $750. ( this listing says $799, but there ebay store has it for $750 so they matched the price) The mains difs between the 6140 and 7140 is the 7140 has
- front, rear and sub output
- $40 Remote is included
- Motorized faceplate (can adjust screen angle)
Other than these it doesn't look like much performance difference for the $300 increase. I would spend the saved money on rear/overhead monitors and backup camera. That's if you don't have money just fallen out of your pockets. I think the extra features are cool, I just couldn't justify spending the extra money. As you can see here I spent plenty in other ares.
Here's my mods list:
Old Man Emu's 901 Heavy Load (350lbs.) Rear Coil Springs.
Air Ride 1000lb leveling air bags in rear coils. Part# 60812.
Dual Viair 480C air compressor and 2.5 gallon air tank.
Firestone pneumatic controller and psi gauge.
Old Man Emu's 303003 Heavy Duty Torsion Bars.
San Diego Off Road Innovations 1.5" Ball Joint Spacer.
4Crawler 4" Panhard Bar Drop Bracket.
JDC Brake Proportioning Valve Relocation bracket.
Extended Brake lines by Trail Gear Inc.
Dual Battery system with quick connects front and rear.
Rancho RS5272 Front Shocks. 1.625" longer than stock.
Rancho RS5208 Rear Shocks. 1.75" longer than stock.
Energy Suspension 9.9101 Bump Stop. 2.125"
Warn Premium Manual Hubs. Part# 28761
JDC Front lower bumper w/2" Receiver and Quick-links.
JDC Safari Rack with KC lights and Hi-Lift Jack mounts.
JDC Extreme duty adjustable lower link arms.
JDC lower front bumper valance.
Custom paint job (color change including jams).
Powder coated bumpers (black hammer tone w/clear).
JDC Replacement Factory graphics.
Body side moldings.
Clear Bra (Paint Protection Film).
Transmission cooler.
Oil filter relocation kit.
LED backup lights in rear bumper.
Hi Lift HL-485 Extreme Jack.
Eclipse Sunshade.
Kenwood DNX6140.
JL Audio component speakers all around.
JL Audio 10" w1 sub.
Dual Pioneer GM Series amps.
Rear backup camera.
I'm getting ready to do a full write up on the deck and install as soon as I have it all buttoned up.
Here is the rest of my 93 4Runner build write up.
