AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Help my NMT player EHP-606 DVD playing
post #1 of 12
Hello Guys, i have a query. how can we get full screen image on lcd with a 4:3 video, played through dvd rom. i tried all settings but the image continues to be 4:3. i have put the latest firmware. from the old firmware i did not have this issue. The tv is a 16:9 sony lcd. if i set it to 4:3 i will have black bands on the right and left.i want the video to be fuuly covered on the lcd.
Did you test a dvd which has a 4:3 aspect ratio and play it on EHP-606 through a dvd rom. and without zooming try out which setting gives a full screen image. zooming the tv or through 606 will spoil the image. I need to have the setting without artificial zooming?
post #2 of 12
Anybody help me?
post #3 of 12
set your NMT player to 480p and ypu may be able to use TV's aspect options to bring 4:3 to fullscreen 16:9, but the picture will be stretched unnaturally, of course...
post #4 of 12
An external USB dvd?
what is the files format?
post #5 of 12
I tried, but it is stretched...veryy embarrassed! Anyway thank you for your suggestion!
post #6 of 12
Yes, it is the file from external USB dvd, all kind of formats they are, avi, mkv... but it seems work very good with the late firmware, after I update the latest firmware: new:090201-(606)softwail[2009-4-15], it happened with such problelms.
post #7 of 12
Well, how about transfer the files from DVD to your NMT hdd since 4:3 files for internal HDD can be played very well?
post #8 of 12
4:3 files from HDD is exactly very good presented, but from external HDD, it is contorted
post #9 of 12
My EHP-606 play one of my files with 4:3 image very well.
You can try transfer the files into internal HDD firstly and watch them thru EHP606.
post #10 of 12
Yes, I just roll back to the late firmware to play these files, it is strang why it can not support, I am wondering the firmware is something wrong. I will update it one again to see how it goes. Anyway, I like this EHP-606 very much!-
Thank you guys!
post #11 of 12
Thank you guys!
hello Baminron, Is your trouble solved? Where did you buy EHP-606?
post #12 of 12
Yes, I made mistake on it and sorry for my newbie!
Thanks Bro!
