AVS › AVS Forum › Other Areas of Interest › Camcorders › Vegas Pro 9 out
Vegas Pro 9 out
post #1 of 24
Anyone know where we can get a trial? It doesn't seem to be availble on the official site..
post #2 of 24
It isn't actually out until the 11th of May.
Steve
post #3 of 24
Steve
I would expect the trial to be out a bit after that, but V9 does look good.
Preorder now and you get $50 off and your choice of one of 3 different plugins or sound effect packages free.
I've already ordered.... just have to wait now.
post #4 of 24
I should also add there is a free update patch from DVD5a to b out right now (some minor bug fixes)
post #5 of 24
Yeah, I've placed my order also... though oddly enough, there is no record of the order on my account and I never received a confirmation email.
Oh well, I have an order number.
Steve
post #6 of 24
What I'm hoping in this one is Video-Redo like Smart Rendering for HD files.
IT doesn't have to be as quick, but I would like to be able to join multiple MTS files without any quality loss
post #7 of 24
Wow 64-bit action, 4k, RED editing! Will there be smoother avchd editing?
post #8 of 24
"Smart render" is not on the upgrade list and one would suspect that if existed they would have mentioned it so I wouldn't hold my breath.
post #9 of 24
I thought this quote from Sony's site referred to "smart rendering" in the section that talks about AVCHD/HDV support:
Vegas Pro 9 software also has powerful no-recompress technology for faster render times.
If not, what does this refer to?
Also, is there a "usual" sequence in terms of the newer version becoming available in the Sony Vegas Movie Studio line? The Pro is still more money/features than I need, and if the next version of Movie Studio will fix the AVCHD rendering bug, that's all I'll need. Any idea on when SVMS 10 would appear, based on the schedule for Pro 9?
post #10 of 24
Is there a Platinum 9 update that addresses this bug?
Pro 8 works great with AVCHD.
post #11 of 24
I think the "no-recompress" is for MPEG2 only as it is on previous version.
post #12 of 24
In a word, no!.
The bug has been known and documented on Sony's support forums for at least 6 months, probably more, and there is no official acknowledgement from Sony, nor any hint of a bug fix.
Quite ironic, in that a Sony product that emphasizes its ability to work with AVCHD files, has problem rendering this very same format, even when using AVCHD files created by a Sony HD Camcorder. Pretty embarassing for them, if you ask me.
I have no hope for a bug fix for SVMSPlatinum 9, and a small hope for it being fixed in Ver. 10 (whenever that is slated to come out).
post #13 of 24
Hey, VideoRedo has a Quickstream Fix option. Does Vegas Pro have something similar?
b
post #14 of 24
In a word, no!.
Maybe they leave it like that so that more people will buy the pro version...just a guess.
post #15 of 24
No way. The pro version is 5 times more expensive, different market. It would be very stupid since they would lose customers to Ulead and Pinnacle instead.
post #16 of 24
I would agree, yet they must be able to fix it, but are not. So, why not?
post #17 of 24
I don't know if Platinum has the same file IO plugins as vegas pro does but we had some crashing problems with pro and avchd that we managed to pull together a work-around for. You can try it on Platinum:
http://www.sonycreativesoftware.com/...ssageID=648152
post #18 of 24
This does sound very encouraging.
Can anybody here who has trouble rendering m2ts/AVCHD files with Sony Vegas Movie Studio Platinum 9.0b try this work-around and see if things improve as dramatically as most are reporting in the thread Bigbarney references?
Bigbarney - do you know if the files he suggests editing would be the same in the Movie Studio version of Vegas? ETA: Just saw that you mentioned you didn't know if the files were the same. Anyone?
Thanks! My trial version of SVMS9 is long expired so I can't try this out, but if results are encouraging, I may just have to buy it and take the chance.
post #19 of 24
thanks for the link, that is interesting... i have 3 hour raw avchd project on the vegas pro timeline right now, but i have no intention of rendering it out to avchd again, so i hopefully won't need to hassle with this.
post #20 of 24
ces?
I have Vegas Pro so to be honest I could not tell you. BUT.... if it's anything like Vegas pro then you should have your main EXE program file (in pro it's called vegas80.exe... in vms it would PROBABLY be vms.exe... or something close to it) located in your root VMS folder. Then in a subfolder called "fileIO plugins" you will find a bunch more subfolders in there. Look for a folder called M2TSplug. It's the dll files in there you need to change the flag on.
This is all assuming of course that VMS is similar to Vegas pro.
post #21 of 24
Just had a look, and you're exactly correct. SVMS9 has the same subfolder and files as the Pro version. Unfortunately, while it is still installed on my system, it is the expired trial version, so I can't use it. I might have to take a chance, as I really need to something to work with my AVCHD files.
Has anybody tried this fix with the Movie Studio Platinum version of Vegas??
post #22 of 24
Vegas Movie Studio 9 Platinum Pro Pack looks to be a separate trial download; which is essentially Platinum 9 with extras included with the program.
If you haven't downloaded that one already, you can see if it works with what you're trying to do.
list of trials
http://www.sonycreativesoftware.com/download/trials
download VMS9PPP
http://www.sonycreativesoftware.com/.../moviestudiopp
post #23 of 24
list of trials
download VMS9PPP
Thanks. This might be an option, as I think I have the plain Platinum version as a trial, not the Propack flavor. Guess I'll uninstall the one I have and try the Propack one, and see if I can get a fresh trial to check this out further.
Don
post #24 of 24
Don
Well, no dice - I either had the Platinum Propack Trial version the first time around, or in any case, after a complete uninstall/reinstall, it's still telling me my trial period is over.
Anybody try the fix that Bigbarney referenced on Sony VMS9b, to see if it enables relatively stable m2ts rendering?
  Back to Forum: Camcorders
