I had a whole page typed out but AVS decided to log me out and I lost it all
Basically I just wanted to know what you guys thought about the distance between the two fronts and if the fronts should be toe-in on the listener or just positioned flat?
I was talking with a very knowledgeable and schooled installer and he said there is a formula to use for the distance of your two fronts.
Distance of TV divided by 1.428 = distance between two speakers
I tried this last night ans was surprised at the results. I have always kept the viewing distance and the distance between both speakers the same. Also I started thinking about the rule of thumb of turning the fronts inward or toe-in. Cinema's don't do this why should I? So I tried this also, turning the speakers outward from the toe-in position that I originally had and now set to a flat plane. Again I was surprised at the results. It seemed to fill the room up better and not as focused. Sweet spot still seemed to be there just better IMO. I don't know, this is totally not what I've been taught in the past and seems a little strange, but I like the results thus far.
Whatch think?
Whatch think?
