AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung PN**B450 Picture Settings
Samsung PN**B450 Picture Settings - Page 37
post #1081 of 1402
Originally Posted by TaichiKid View Post
My Colourspace settings are the same, except one My Magenta has a HUE of 0x16 vs your 0x17. I am in western Canada, and my panel was from Jan 2010.
I believe Canada uses the NTSC (North American Television Standards Committee) signal format and therefore, the references should be the same. Don't know why they changed Magenta and only by one count less.
post #1082 of 1402
Originally Posted by kanpol View Post
Are you refering to my colorspace default(US) or Mac4ps colorspace default(EU).
My defaults are
W2_Rgain-131
W2_Bgain-91
W2_Roffsets-119
W2_Boffsets-121
I was referring to mac4ps's European Before settings, since he gave us the After settings.
My own default Before settings are:
Warm1 Warm2
146 135 RGain
109 92 BGain
117 106 ROffset
124 135 BOffset
post #1083 of 1402
And for anyone who want to compare, here are my deault settings...
In contrast to the classic CRT calibration/s I still did a whole 4 - 5 years ago today's sets have no deflection yokes, no power supplies set to approximately 31.5 KVolts, no differing crystal clocks, no discrete circuit boards, or delay lines.
The sets today are uniformly derived with phase locked loops, crystal countdown to 1/100 million, digital signal processing, zener diode based voltage supplies, uniform lead inductance & capacitance vs discrete boards.. Even plasma cells are pretty uniform.
One observation I have is that most in this forum are loath to turn on digital edge detection. I would beg to differ.
For one thing, non hi-def broadcast is still 480i in N.America, and 576i in Europe. Zoom that picture up a lot & the pix often look fuzzy.. The old edge enhancement algorithm used the trick of making any edge look like a square wave by increasing the high frequency components, increasing upper Fourier transform components, modern DSP also uses matrix edge detection based on context. The modern stuff first extrapolates whole edges using matrix based image processing before deciding something is an edge, and then unobtrusively as possible enhances only a real edge..
Give the digital edge enhancement 'ON' a try if you see a fuzzy picture.
Here are my default service settings. I would be interested in seeing others in all regions.
DefaultPNB450Settings.pdf 48.05859375k . file
post #1084 of 1402
my defaults are the same as yours and i live in USA(ny)
post #1085 of 1402
my colorspace is the same as yours and my W1 and N1 is the same also. But my W2 is different, mine is
W2_R GAIN- 131
W2_B GAIN- 91
W2_R OFFSETS- 119
W2_B OFFSETS- 121
I'm just wondering why mine is different then both of yours and mine is USA(CA.)
post #1086 of 1402
C450 owner here, having a question about the b450 models with regards to color space of auto vs. native. I have noticed on my c450 plasma that the auto color space fluoresces blues and reds when compared to native color on OTA HD signals (haven't tried with Blu-Ray). Eg: On the recent Cavs/Bulls NBA telecast, the red uniforms of the Bulls were much easier on the eyes and seemed much more accurate with the native setting than with auto setting on my c450 plasma.the reds were deeper and less fuzzy. To me, it would seem as though the function should be the opposite for auto vs. native, meaning that native should be expanding the color space beyond the sourceso I started to tinker with my Samsung LCD.
When testing out my Samsung LCD, the native color space ends up fluorescing these reds/blues, whereas auto tones them down. I'm curious as to why these settings are flip-flopped in for the plasmas vs. LCDs. Can anyone test their B450 to see what these respective color spaces do to reds/blues? Test to see if there is a noticeable difference on various sources?
post #1087 of 1402
Originally Posted by jamesco411 View Post
C450 owner here, having a question about the b450 models with regards to color space of auto vs. native. I have noticed on my c450 plasma that the auto color space s blues and reds when compared to native color on OTA HD signals (haven't tried with Blu-Ray). Eg: On the recent Cavs/Bulls NBA telecast, the red uniforms of the Bulls were much easier on the eyes and seemed much more accurate with the native setting than with auto setting on my c450 plasma.the reds were deeper and less fuzzy. To me, it would seem as though the function should be the opposite for auto vs. native, meaning that native should be expanding the color space beyond the sourceso I started to tinker with my Samsung LCD.
Hopefully the functions are not flipped around (although anything is possible with Samsung). The "NATIVE" setting belongs in the service menu since it should never be used for normal viewing. If the colors appear to fluoresce and/or are fuzzy, that's a good indication that the "COLOR" setting is set way too high. Try turning down the color... the color shouldn't jump out at you. Set the color level to give a natural looking flesh tone. Good luck
post #1088 of 1402
My color is at 38.....vs. the default of 50
post #1089 of 1402
The color setting of "38" seems a good in the ball park number. The only other things that come to mind are high brightness, but that would wash out the picture, or the signal itself. Sometimes broadcaster really turn up the saturation. If its a new set...I might call Samsung about it if its really gets to be a problem. As far as the color space settings, the "AUTO" mode should be set and will generate the rec601 or rec709 color space, which are the only two standards that are currently used for standard definition or high def.
post #1090 of 1402
This one is driving me batty; I get a delay out of the optical audio output somewhere between 65 and 75 msecs, does anyone have a number which worked well for them? I am guessing that the delay in the video processing circuitry is uniform because it is all in one unit.
post #1091 of 1402
i dont notice a delay when i connect my dig. cable box to my audio receiver with optical audio
post #1092 of 1402
good evening all, got a question regarding debug mode in the service menu. It has 3 choices off, smart and runtime, was wondering what is it for? It is located in advanced menu under adjust.
post #1093 of 1402
I was talking about a delay out of the TV's optical audio output. I have been adjusting and find 80msecs pretty good, but not perfect.
post #1094 of 1402
Originally Posted by dogukan View Post
i accessed service menu today.the code is INFO + MENU + MUTE and then press the power button.but you should be really quick. i tried mac4ps ' s settings. actually it looks really good on samsung pn50b450. my reds was really bad and it looks really good right now.thank you guys.
Is there a trick to getting into the service menu? If I'm understanding correct, with the TV turned off hold down the INFO+MENU+MUTE buttons on the remote, then release them and press the power button. I've tried probably 50 times and can not get it to work.
post #1095 of 1402
If that method doesn't work, your set code is probably 1 + 8+ 2 + Mute. I have the 42B450 (US) and 182Mute is my code.
As a word of caution though, going in and changing only the CMS values as above isn't a problem, but there are settings in there that can make your tv not work. AT ALL. So don't touch a setting unless your absolutely sure of what it does.
post #1096 of 1402
the 1, 8, 2 mute then power one is mine
post #1097 of 1402
thanks guys. I'll try that when I get home.
post #1098 of 1402
I swear I'm not an idiot guys, but I've just spent the last 20 minutes trying to get into service menu and just can not figure it out.
At the risk of sounding even dumber than I already do, can someone please verify the exact sequence needed?
You hold down 1+8+2+mute at the same time, correct? Do depress them simultaneously or does that not matter? Then you release all 4 buttons and press the power button. correct? how quickly do you press Power? immediately or after a second or so?
argh!!!!
post #1099 of 1402
hey spon, dont worry your not an idiot, sometimes they are picky thats all. If you have a US tv then turn it off, now making sure remote is pointed at tv hit mute then 1 then 8 then 2 and then power. you should be in the service menu. You will know cause you will see some menus on the upper right hand side of your screen. to get into advanced its press 0 five times back to back. be careful in there ok
post #1100 of 1402
thanks Kanpol! I was trying to hold down 1+8+2+mute at the same time instead of in sequence. *duh*
here were my default settings in case anyone is interested. I have to say, the new settings don't look good at ALL on my set. The whites seem washed out and everything seems a bit blurry. My defaults were pretty far off for some reason. I'm in Los Angeles, but the set was bought from Amazon, so who knows were it came from.
Mode: Off
Color Mode: movie
color tone: warm2
Msub Brigh 128
Msub Cont 128
W2_RGAIN 132
W2_BGAIN 90
W2_ROFFS 109
W2_BOFFS 130
N_RGAIN 138
N_BGAIN 126
N_ROFFS 112
N_BOFFS 131
Movie Contr 95
Movie Brigh 53
Movie Color 50
Movie Sharp 20
Movie Tint 50
Movie BkLight 7
M.Gamma Off
M_Sub Gamma 0
color space
Red Sat 0x17
Red Hue 0x40
Green Sat 0x1A
Green Hue 0x40
Blue Sat 0x16
Blue Hue 0x40
Cyan Sat 0x17
Cyan Hue 0x3B
Magenta Sat 0x16
Magenta Hue 0x40
Yellow Sat 0x10
post #1101 of 1402
hey Spon, your default colorspace matches my default. You can turn the mode to on and put the settings you want to use for movie mode (example contrast brightness color tint) that way it will automatically keep settings you want as its default. If you change the default settings from colorspace and the the W2 W1 N, make sure your either write the defaults down or take a picture of them. If you go into the expert section of the service menu you can turn N/D adjustment to on and you will have cal-day and cal-night mode. For that to work you will also need to change your tv model to b560 or b590. That wi9ll also enable cinema smoooth.
this link will explain it all in detail, just be careful, please
http://www.avsforum.com/avs-vb/showthread.php?t=1175569
post #1102 of 1402
EE Engineer, if your still reading this thread was wondering if you ever had the chance to calibrate your tv using the colorspace in the service menu. If you did, if you dont mind me asking, how did it come out.
post #1103 of 1402
what did you change your model too(if any at all)? which is better
post #1104 of 1402
I think I changed mine to B590 but B560 wil work too, not sure which is better
post #1105 of 1402
thanks for the link. I think I'll try that out when I get home. Just to clarify my last post- I did change the defaults to the suggestions posted earlier in the thread. What I found is that the picture (to my eyes) now look substantially worse than it did before I changed the defaults. I just can't seem to get Movie mode to look even halfway decent no matter which settings I use. Standard mode looks better, but it also seems off. I suppose I should have it professionally calibrated, but I really don't want to drop the extra $$.
post #1106 of 1402
Originally Posted by mac4ps View Post
Hey, my first post. My tv is the PS50B430 (european model) Here are my settings after calibration with HCFR and DTP-94. I use the service menu because it is easier and I have more options (CMS) and it allows to make your settings as default at least for the movie mode.
Before make any change in service menu write down default settings.
Enter Service Menu: with the TV in stantby press in the remote control INFO + MENU + MUTE and then press the power button.
Highlight ADVANCED and then press 0 0 0 0
Then you go to WB Movie and set MODE to ON to activate. Now everything you set is the default mode for movie.
My settings are:
WB MOVIE
Mode - ON
Color Mode - Movie
Color Tone - Warm 2
MSub Brigh - 128
MSub Contr - 128
W2_RGAIN - 121
W2_BGAIN - 90
W2-ROFFS - 86
W2-BOFFS - 67
MOVIE CONTR - 86
MOVIE BRIGH - 48
MOVIE COLOR - 48
MOVIE SHARP - 0
MOVIE TINT - 50
MOVIE BKLIGHT - 10
M. GAMMA - 0,93
M. SUBGAMMA - 0
Now you press RETURN and go back to previous menu. Then you must go to COLOR SPACE. This is the CMS. These are my settings;
COLOR SPACE
RED SAT - 0x12
RED HUE - 0x23
GREEN SAT - 0x13
GREEN HUE - 0x3F
BLUE SAT - 0x1B
BLUE HUE - 0x49
CYAN SAT - 0x07
CYAN HUE - 0x18
MAGENTA SAT - 0x19
MAGENTA HUE - 0x1E
YELLOW SAT - 0x0C
YELLOW HUE - 0x0B
FWC BLUE 0x0F
FWC RED 0x0F
By the way if anybody knows what is FWC please post it.
These are my results:
Greyscale:
Gamma:
RGB Levels:
CIE Chart (rec709)
Best
mac4ps, can these settings be used for european model samsung ps-c450?
thanks
post #1107 of 1402
thanks
I have no idea but it would'nt hurt to try them. Write down your defaults first.
Best
post #1108 of 1402
Hi, I am a novice with this stuff. I am looking for the best settings for tv viewing, particularly for sports, etc. I tried a couple of the recommended settings, but it seemed a little dark. Thank you for your help!
post #1109 of 1402
mac4ps- Using your settings, I feel like my whites are very washed out, almost yellowish. Could you recommend any changes to the settings in this situation?
Dallows- I was wondering if you'd mind posting your current settings. Reading thru all of your older posts, I feel like my set is similar to yours. I just can't get a decent picture out of Movie Mode.
thanks
post #1110 of 1402
Just ordered my 50" B450, should be here next week. I'm having buyer's remorse; I think it might be a little too big for the bedroom wall. It's not a large room, maybe 13x15, with the bed and TV on opposite sides of the shorter dimension. Perhaps a 42 would have been a better size?
