Greetings direwolf2009,
Here are my final recommendations based on previous postings. Many configurations were given due to updates from my ongoing calibrations. But I think the below settings are about the best I can recommend.
You may want to consider using the screen fit setting instead of 16:9 to obtain 1:1 mapping of the tv's pixels for a potentially better picture, but keep in mind that the screen fit setting may turn off a safety feature that may protect against image retention. I haven't had any problems using the screen fit settings.
Also, a note about sharpness: After setting sharpness, if the picture appears to be slightly fuzzy, you may want to consider using an hdmi cable with ferrite (magnetic) cores and a ferrite core on the power cord near the plug to prevent or reduce electrical interference from other devices/wiring. Samsung recommends use of a ferrite core, which is included with this tv, on the power cord for this model.
The 10% Windows, 22% APL is a calibration pattern found on the Gamut Calibration Disk that was created by members in this forum. It is recommended that this pattern be used to calibrate plasma tvs due to technical problems in using other common calibration patterns. I use this pattern from this disk in my blu ray player when calibrating the tv with a colorimeter. There is no setting on the tv for this pattern.
See the following thread for diy calibration techniques used:
http://www.avsforum.com/t/1430821/some-diy-techniques-in-calibrating-plasma-hdtvStandard HDMID93 Color Temperature Settings
screen fit
GCD 10% Windows 22% apl
standard mode
color tone cool
cell light 9
contrast 83
brightness 46
sharpness 1
color 48 DVE Pattern with Blue Filter
tint 53/47
black tone off
Gamma -1
auto color space
cuts Red 16 Green 19 Blue 19
Gain Red 39 Green 30 Blue 34
All other enhancements off, including edge enhancement
Bonus Standard HDMI12000K Color Temperature Settings
screen fit
standard mode
color tone cool
cell light 9
contrast 83
brightness 46
sharpness 1
tint 53/47
black tone off
Gamma -1
auto color space
Offset Red 17 Green 19 Blue 21
Gain Red 31 Green 30 Blue 42
Movie HDMI
screen fit
10% Windows 22% APL
Movie mode
color tone warm2
cell light 9
contrast 87
brightness 45
sharpness 5
color 48
tint 52/48
black tone off
Gamma 2
auto color space
cuts Red 35 Green 29 Blue 46
Gain Red 44 Green 23 Blue 37
screen fit
HDMI Black Level greyed out
Standard Component
screen fit
standard mode
color tone cool
cell light 9
contrast 84
brightness 46
sharpness 1
tint 53/47
black tone off
Gamma -1
auto color space
cuts Red 10 Green 17 Blue 17
Gain Red 42 Green 30 Blue 35
Movie Component
screen fit
10% Windows 22% APL
Movie mode
color tone warm2
cell light 10
contrast 93
brightness 45
sharpness 4
color 48
tint 53/47
black tone off
Gamma 2
auto color space
cuts Red 26 Green 32 Blue 46 Corrected
Gain Red 41 Green 18 Blue 37
screen fit
Vincentfam
Edited by vincentfam - 11/23/12 at 4:36am
