Originally Posted by stereomandan
Well, now that I've had a chance to see the photos on a decent monitor, I can say without a doubt that my plasma looks nothing like the #2 photos. I don't have the red tint, the fuzzy picture, the lack of "pop" as seen in the #2 photos. Mine has neutral greys, a very clear picture, and good shadow detail while maintaining good dynamics.
I'm surprised that some see such a large "degradation" in Movie, warm 2 mode.
Either there is significant unit to unit variation with these plasmas, or dallows camera is having a major impact on the orignal image. My guess is that dallows B450 just doesn't calibrate the same as mine. If this is true, then it is a major bummer since our settings won't be universal.
I will take photos of my settings, on my plasma, and once I post them, we can discuss further.
dallows, if you are using my settings, change the gamma to -1, like you have in your standard mode, and it may help significanly with any "cloudy" look you may be seeing.
Dan
Dan
Well at least I feel a bit better now that I'm not insane. I don't think it's the camera as they're fairly close to what I see on the display. If anything it helped a little, haha.
Last night I tried a couple resets including a factory reset (I'm almost afraid now that the standard calibrated image isn't like it was, but that could just be me or the channels I was watching - didn't use blu-ray yet), but it didn't improve the movie mode.
The image looked basically the same even after using a calibration disc, so I'm pretty sure it's something with the panel, maybe in the service menu (if there are even more controls there).
I might try to hit up Samsung support to see if they can shed any light. While I know there can be differences even within the same model line, I don't know if they should be as drastic.
Dan, I've tried messing with the gamma as well, didn't really do much.
Thanks guys.
