Netgear and Dlink both released Moca (something like media over coaxial).
Long time coming really. It uses existing coaxial in your house to adapt with ethernet. It should be a lot better than RJ-11 or power because the bandwidth of coaxial is really high and the cables are almost always high quality, plus you can make it closed circuit if necessary.
The theoretical max is 270Mbps, though I'm not sure of the actual. Considering the theoretical max of even 802.11n is about 75mbps, and from what I read, MoCA is a lot closer to it's theoretical.. I'm not sure if cable modem use hinders performance, but it seems like it operates outside of normal frequencies used by cable companies and it does have a rather HIGH frequency range!
http://www.dlink.com/products/resour...Specifications
I found the Netgear one for sale for $175 a pair. The D-Link for about the same price.
They just announced both of these this week. I imagine Linksys may hobble along here eventually..
