AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › WD TV Prerelease 1.02.07 is out
WD TV Prerelease 1.02.07 is out - Page 6
post #151 of 569
Originally Posted by Ph8te View Post
Not sure what you mean by additional encoding support, as I am new to the whole ripping\\encoding thing.
Settings > System on the WDTV. You must choose the encoding related to that language.
post #152 of 569
I guess I mis understoof you, the movie is in English, there is a small part where they speak a foreign language. This Language is translated into English via embedded subs. Before with movies I have always left it to the default (Western Europe) for addtional endcoding support. This was the first movie, where the subs came up and went away too quickly (displayed for 1 second or so).
post #153 of 569
Originally Posted by Maccam View Post
I'm having trouble with a couple of 720p .MKVs (video goes choppy and looses audio sync)
Does anyone know how many ref frames are allowed in 720p to play smoothly in the wdtv?
I know the limit for 1080p is 5 but no one mention what happen with lower resolutions. (wiki isn't very clear...)
Thx
There is no reference frame limitation when it comes to 720p files. So your playback problems have a different cause. Post the MediaInfo details.
post #154 of 569
thanx WD , the prerelease works great with me , But we r still watitng for the Arabic support
post #155 of 569
Ok
The problem is low framerate (harder in the first one) and audio out of sync. I've tryied them with the official release as well and the choppy video is still there although audio seems to be in right place. Btw subtitles and audio are sync in both cases.
Any clue?
Attachment 140595
Attachment 140596
Thx
mediainfo1.txt 1.8388671875k . file
mediainfo2.txt 1.072265625k . file
post #156 of 569
Excellent job guys, congratulations.
Now that the tech issues are almost solved, should be a good time to improve the user interface.
Whises to add in future version:
Enter button and arrow keys:
- Pressing the "enter" key: once for status bar, twice for status bar + options bar, and third to quit.
- More options and features in options bar.
- More info in status bar (chapters, sounds, definiton, etc)
- Arrow keys for volume, ff/rew and x10 minutes.
- Advance page in file list with arrow keys
Files info and options:
- More info about the files in the menu (sound, sub, etc.)
- Copy, paste, delete, move
Hardware support:
- USB hub
Menu navegation:
- Faster speed in menu transition
Option button:
- with the first point, this button has no sense, so you can use it for something.
post #157 of 569
Originally Posted by hidalgo76 View Post
+1!!!
Thanks for your hard work and for listening to your customers.
But this DVD menu support for VIDEO_TS and ISO files should be added to have a full multimedia device.
Or at least confirm us if this is possible to add this feature or for licensing issues you cannot implement it to the WD TV.
+1, for me .iso backups are quickest to create with no loss of quality .. and having the menu's and chapters working would be great.
post #158 of 569
Ok
Any clue?
Attachment 140595
Attachment 140596
Thx
At first glance, there is nothing wrong with the files, although it's unusual to see a 4.1 profile video with 11 rf (1st example). Do they play without a hitch on the PC? VLC is a good choice for spotting glitches / problematic files.
You could try to remux those files again, e.g. remove the subtitle track from the first file (just an idea), or use tsmuxer to mux them to .m2ts. Could be worth a try.
Sorry that I can't be more of a help, but just going by the Mediainfo details, your WD TV-HD should be able to play back those files properly.
post #159 of 569
you can do that now with the PREV/NEXT buttons
post #160 of 569
Dear ScottWD and GuyWD for the excellent work !
still - there is no support for HEBREW subtitles (.SRT)
when is it planned?
another question to the Forum - is there a support for card reader through USB ? i tried to use a SD card with a card reader and it was not identified.
thx in advance
post #161 of 569
when is it planned?
thx in advance
I have used a 1 gig micro SD card and it worked with a usb adapter.
post #162 of 569
Yes I know, but should be better in the arrow keys, in order to avoid move the fingers to find the right button.
It is just a suggestion
post #163 of 569
I'm no expert at this, but wouldn't it be possible to create a workaround for DVD menus ? WD would document a file format (TXT or XML) from which WDTV would read menu information for a DVD folder and display it. Something like:
Code:
Then we can create a program for reading original DVD menu information and generating menu information file from it.
I repeat: I'm no expert and I don't know if this is doable or it's just a stupid idea.
nivazno.
post #164 of 569
Originally Posted by polakis View Post
Scott and GuyWD thanks for your updates. The latest firmware is very very good!
Only one problem remains. I am Greek, and the greek subs problem isnt fixed yet!
We still have out of sync greek subs and flashing greek subs! Please do something! And i havent checked about greek letters È and ¢ problems.
Please fix them and everything will be perfect after that...
+1
We cannot check the new features without greek subtitles (we are just installing the new firmware's to see what is fixed and then returning to the latest final so our wife's can see a movie )
Thanks! and keep it up
post #165 of 569
Oh, so the text, on the subs is in english? Post the srt (do you know how to extract it from the mkv?) here, on an attachment, and i'll dig into the matter.
post #166 of 569
Originally Posted by alruban View Post
is it still does not support arabic subtitle
+1
post #167 of 569
Arabic are Right to Left (same for Hebrew), so they need additional coding not needed for other languages. You have to wait until put this in their plan. But you can use idx/sub, I suppose.
post #168 of 569
I agree and made the same suggestion on the 1.02.06 board. also got a few PM's there from people who didn't know there was a page up/down function.
I've also been hinting at the volume output control since december.
Maybe one of these days...
post #169 of 569
WD,
Feature request:
While file playing:
Right arrow: 30 second skip forward
Left arrow: 7 second skip back
These increments work well for skipping commercials in recorded TV shows.
Bob
post #170 of 569
Originally Posted by cerulean View Post
WD,
Feature request:
While file playing:
Bob
I agree with the suggestion.
The current 10min skip is definitely too long.
I would prefer a 5min skip (and then pressing twice the button) rather than having a long skip and no other option.
Actually, it would not be bad to have the skip duration selectable (between 1min and 20min) in the settings section.
post #171 of 569
WD,
Feature request:
While file playing:
Bob
Why do you keep the commercials? Edit them out if you are going to keep the TV shows long term on the WD TV.
-Mod
post #172 of 569
Ok
Any clue?
Attachment 140595
Attachment 140596
Thx
Hi!
Maybe the file is asynch because of the different Frame rates, one's 24 fps, the other 23.976 fps.
You could try mkvtoolnix 2.7.0 and change the Frame rate to the one of the working synch file...
Greets!
Chris
post #173 of 569
well with the last prerelease firmware I should note that MyBook Essential (1TB) does not spin down...
Maybe in the coming updates...
Thanks for the work.
post #174 of 569
7 second rewind would be nice... there are something that make me want to re-watch a part, like if I accidently missed some dialog when someone walked into the room.
post #175 of 569
List View still showing 5 lines of the same file in the folder. If you have 100 files in the folder, List View will show 500 files in total. Not a big deal, but annoying when you have files saved both in the root and folders.
post #176 of 569
My 2.5 inch bus powered satadrive (FUJITSU MHY2250BH 250 GB) doesn't spin down. it's build in in an enclosure from MSI STARBOX.
Also another issue, when i've ejected my drive and turn my WD off and on again with the drive connected, the WD doesn't recognize my drive (No storage present). The only way I can get it running again is by removing the usb cable from the drive and plug it back in again.
Keep up the good work guys at WD !!!
Sorry for my bad english (from the netherlands)
post #177 of 569
That's a function I frequently use on my DVR, and often find myself reaching for the remote for while watching WD/TV. Way outside the scope of this thread, but I'll give it a +1.
post #178 of 569
That indeed would be a handy feature to have
+1
post #179 of 569
I'm not sure if this is a known issue, but subtitles in idx/sub format don't seem to get the thick borders when selected.
The below example is from the animated film 'Persepolis'. In this screenshot it's clear why either a)borders or b)different colors are needed for subs.
This image has font=40 and border=thick in the settings. subs are in idx/sub. Firmware is latest 1.02.07 (sorry for the glare on the tv, i don't usually watch in the daytime)
post #180 of 569
When i eject the Hdd it ask me to Cancel or Ok but default is cancel and i have to move fingers to arrows and then hit ok .... why ?
if i press eject button it's not clear that i want ? default it's to be OK
then i press OK button
if i mistake press eject then move fingers to arrows and select cancel and OK
that it ... the same thing on update fw .. ok default
thx
