Yes, they look also really nice!
At this time, the source file was:
Code:
General
Complete name : G:\\Nueva carpeta\ s-septic.mkv
Format : Matroska
File size : 3,73GIB
Duration : 1h 42min.
Overall bit rate : 5 204Kbps
Encoded date : UTC 2009-04-11 14:21:29
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Si
Format settings, ReFrames : 5marcos
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 459Kbps
Nominal bit rate : 4 561Kbps
Width : 1 280pixeles
Height : 536pixeles
Display aspect ratio : 2.35
Frame rate : 23,976fps
Resolution : 24bits
Colorimetry : 4:2:0
Scan type : Progresivo
Bits/(Pixel*Frame) : 0.271
Stream size : 3,19GIB (86%)
Writing library : x264 core 67 r1130 8475977
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=4561 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : Inglés
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constante
Bit rate : 640Kbps
Channel(s) : 6canales
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48,0KHz
Stream size : 470MB (12%)
Texto
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
