I am rebuilding an old HP 933Mhz Pavilion into a media server. I had one before, but took it down about 8 months ago. Anyway. It is now a 1.8 Celeron foxconn system with 384MB of ram.
The Hard drive that I have in it as the boot drive is a WD 500GB Caviar SE16. Will be adding a pair of 750 GPs next month that I have sitting around.
Anyway, the 500gb was a pull from my new desktop build and had three partitions on it. XP, W7 Beta, Linux (ended up not getting installed so it was empty). Rather than doing a complete wipe, I decided to use the XP partition as the boot os for the server. I don't want to get into a WHS versus linux versus unraid discussion.
Anyway, I couldn't boot into W7 as it doesn't have enough ram. I erased the W7 partition, reduced the XP partition. I currently have it allocated 40GB for Windows XP plus Nero 7 for backups, and the rest as a logical drive. Problem is that the boot sector still thinks there is a W7 partition and it is set as the default. I could just restore the XP partition using the install disks, but I would rather not if possible.
Any good free apps out there that will do this? I can't access the W7 boot sector under XP from what I have tried... just the old xp boot sector.
Worste case scenario, I guess I can't just reinstall Windows on it.
I considered WHS, but I like the gui drop and drag folders over what I have read is used in WHS. For my purposes, I really am only using it to store media as well as a back up for critical documents. I have Nero back it up on there to automatically back those critical files on the other drives weekly.
