AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-SR507 Owners Thread and First Impressions
Onkyo TX-SR507 Owners Thread and First Impressions - Page 4
post #91 of 516
Originally Posted by cpostma View Post
I was almost set on this receiver until the problems mentioned in this thread.
Has the issue with no bass when using PCM been resolved? I plan on using a PS3 so I understand I will be using PCM almost exclusively.
If I remember correctly, that was only one user and it could have been user related.
post #92 of 516
Originally Posted by GreatGold View Post
Hi All,
So I understand that both the 507 and PS3 can decode the HD audio formats. My question is which does it better, or are they both equal so that it doesnt matter? Currently I have the PS3 decoding the audio and sending it out via LPCM (which reads as Multichanel on the 507). Would it be better to send the audio from the PS3 as bitstream, and allow the 507 to decode? If they are both equal, I suppose sending it as bitstream is better so that I can see on the display what format is in use, correct?
No difference in sound quality, but the PS3 cannot bitstream the HD audio, only PCM, so it won't matter until you get a BD player than can bitstream HD audio.
post #93 of 516
To control the fairly new items (Onkyo SR507 and Samsung b750 LCD TV. The remote-input codes for the Onkyo are different for on and off. Thank you. dennis (nyc)
post #94 of 516
Originally Posted by MVBJJ View Post
I have this receiver on order then realized I need Front A/B capability to handle 2 sets of front speakers, one set of flush mounted in my ceiling and another set of bookshelf speakers. My rear speakers are also ceiling flush mounts. Can someone confirm there is no capability for front a/b speakers? What is my best option? Speaker switch? Can the pre-amp out be reassigned for front Bs or does that only run surround backs?
Hey "Skismuggs". I love Smugglers! Grew up in the Northeast Kingdom now living in So. Cal.
From reading the manual, my understanding is that you can hook your two ceiling speakers (or the bookshelfs) to the Zone 2 connections, and then just turn Zone2 on and have it use the same source as the main. However, after typing that I think that'll work but will shut off the 2 rears as it needs to distribute the power. You can view the manual from onkyo's site.
post #95 of 516
I ended up running a speaker selector switch to run front a and b speakers. Works just fine. I am running a set of speakers off of zone 2 for my patio which is just outside my family room and there is a noticeable delay in the audio from the front channels. Probably because zone 2 is analog vice digital up front and there must be a delay associated with the analog circuitry. I guess my point is I wouldn't put my zone 2 speakers in the same room as your fronts.
post #96 of 516
Will Oknyo USA be getting the TX-SR577 variation of the SR507?
post #97 of 516
had my tx-sr507 for a week now and so far i love it. I came from a sony ht-ct100 soundbar. Im running a 3.1 setup right now with Energy C100s as mains, Energy C-C50 center, and a tSc asw-10 sub. Setup was very easy, finally got a chance to run Audyssey this weekend. I thought my blu-rays sounded good before but WOW, watched The Incredible Hulk last night and I was blown away.
post #98 of 516
I have decided to go with the 507 over the 607 because I just can't justify the price difference for the 607 and I hear upconvert is over hyped anyway. I'll be hooking up my HDDVR,BluRay,Xbox 360(uses component)and a nintendo Wii.Does anybody see a problem with this? I currently have my xbox connected directly to the tv and optical used for the audio through the receiver.The hddvr and bluray use hdmi of course.The Wii is on the way.Let me know,planning on pulling the trigger tonight on it.Thanks
post #99 of 516
I have (and it had been working correctly) the new b75 hooked up to the Onkyo exactly as the diagram in the set up requires but the TV identifies "Cable 3" and says "weak or no connection" All connections between the TV,etc are via HDMI with DVD going to HDMI 1 and cbl/sat to HDMI3. The new Samsung goes from the HDMI out on the Onkyo to the HDMI in on the TV. why was it working and now stopped?
post #100 of 516
All components are via HMDI as per the Onkyo diagram (BR disc, Fios HD box/dvr, TV) Here is how it is set up in the Onkyo setup menu: Hardware setup-7.3 HDMI: HDMI Contol: On, Power Control: On, TV Control: On, XV Clor: disable. Does this read right to you please?
post #101 of 516
Are you using multi remotes to control your components or one remote to control all your components?
post #102 of 516
Ok I'm going to be banned from this forum for this answer but here goes. I tried programming the Verizon to the codes for the other components and it works sometimes and not others. I then tried to enter the codes in the Samsung and it similarly works sometimes. One specific problem I have identified is: the On and the Off on the Onkyo have different codes. So my answer is thus: I sometimes flubber through one and sometimes all. While I am willing to purchase a more elegant solution (universal remote) I am weary that the new remote (logitech?) will (A) further confuse me, and (B) have similar "partially effective" issues. Lastly as an attempt to just try one I bought a Radio shack universal which barely accepts any of the codes and which i'll return. Excuse the long answer. dennis
post #103 of 516
Dennis I think this is the reason you lost TV connection/signal. Using the remote that don't have all the capable function and by a push of one button may have switched your input mode. I'm not sure if this the case but others can chime in on your settings.
post #104 of 516
Well I'm willing to order a Harmony 1 on Amazon right now if it will control all my "new stuff". Most especially the Onkyo as that is the hub from which all else communicates. Indeed I purchased the Onkyo for expediency (HDMI) replacing my old Yamaha.
post #105 of 516
Dennis,
I use the Harmony1 and it works great.
Along with the 507 I control my Sammy A650 and a Directv PVR.
~~P
post #106 of 516
I started with the Harmony 520 and moved up to the Harmony 880. Absolutely love it! If you want to start cheap to see if you like the Harmony concept, you can get a refurb 520 from Tiger Direct for $39. I got one as a spare.
post #107 of 516
When I turn the Onkyo on with Cable/sat as an input it picks up the audio transmission from my Verizon/Fios dvr/hd box. When I then turn my TV (Samy b750) on the Onkyo remains on the Cable/sat input for a moment but then automatically defaults into the TV/tape input (which gives me no audio from the TV or cable) so I have to set it back to the Cable/sat which is where I want it and set it in the beginning. Why (after a fraction of a second) is the Onkyo input defaulting into TV/tape after the TV is engaged when I put the it on Cable/sat initially? All cable connections are HDMI: Onkyo- fios box/dvr. Onkyo-TV. Onkyo to BR disc player. Hardware setup: HDMI control On. Power control On. TV control On. Thanks. dennis p.s. I ordered a Harmony 1 remote from amazon
post #108 of 516
What do you guys think of the Audessey Dynamic Volume (loudness changes) and Dynamic EQ (low volume optimization)?
post #109 of 516
I believe it happens because the receiver detects your TV and components powering on over the HDMI signal. Turning of TV Control in the Hardware Setup should stop it from happening.
Alternatively, turn on your TV first?
post #110 of 516
I have pretty much decided to replace my Pioneer receiver with this one. I have been using the analog outs on a BD-50 to output the new sound codecs and I am unable to equalize the speakers successfully.
My setup is as follows:
Panny BD-50
Oppo 981
Direc-TV HD
Sammy PNA50A550
My only question is can the satellite HDMI be passed through with the receiver off and still receive the signals at the TV. I seldom use the receiver while watching TV. I looked through the threads and they were inconclusive.
post #111 of 516
When reading the specs I can't find where this receiver decodes DD or DTS. I have a ton of old DVDs that I don't plan on ever moving to blu. Any ideas?
post #112 of 516
Yes. It's not enabled by default, but both Audio and Video can be passed thru HDMI when the receiver is in standby mode. It's covered on page 77 of the owners manual (available at onkyousa.com)
post #113 of 516
I can decode TrueHD and DTS-HD, and it can definitely decode the older codecs DD and DTS.
post #114 of 516
Anyone know how this compares to the Denon AVR-1610?
post #115 of 516
Will the 507 do the OSD over HDMI? I don't want to have to keep a s-video connection around just to look at my settings.
post #116 of 516
Amazon is running an unadvertised discount on the -507. Put it in your shopping cart, pick free shipping, and a discount of $51.60 is automatically applied. This message originally appeared courtesy of someone on the -607 thread ($74 discount).
post #117 of 516
The winner is you, Barometer.
purchased.
post #118 of 516
I ordered a 507 yesterday from 6ave.com. They have a NameYourPrice sale and I couldn't pass up what was accepted.
Now I just have to wait 3 weeks for it to come back in stock.
post #119 of 516
purchased.
Glad I could help, but it was 02ephatch who originally posted the news on the good deal. He da man!
post #120 of 516
I was on the fence, deciding between the 1610 and 507. They both do HDMI Audio on inputs, they both come with Audyssey setup mics. The standout differences that I saw were ...
Denon: 480P upscaling, Only need single HDMI cable to TV (regardless of input source, it can be converted to HDMI output)
Onkyo: 1 extra HDMI port, 2nd zone, cheaper, shipping sooner
I got the Onkyo for the extra HDMI port and because it was shipping sooner. All of my source components are 480P or higher already, so the upscaling wasn't too important. I can handle running 2 cables from the receiver to my TV (one HDMI and one Component).
