AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official HSU ULS-15 Thread
Official HSU ULS-15 Thread - Page 80
post #2371 of 2549
Originally Posted by pgodden View Post
I will give this a go too, should there be a ground connection on the receiver? or just ground from any screw on the back?
Originally Posted by pauleyc View Post
My receiver had two connectors for an antenna and one was supposed to be ground. Worked perfect. But yes, any screw on the main chassis will work also. Doesn't have to be much, I used an 18g speaker wire.
I really do not believe it is a ground loop. Only because the ULS-15 uses a two prong plug and most ground loop issues tend to happen when there is a three prong power cord involved.
post #2372 of 2549
Hmmm... I think I found what I'm looking for. Any suggestions on a receiver?
So even though there is the wireless, I can still use wires to the sub right? I see XLR inputs as well as the low level and high level inputs. Whats the difference in using the 3 inputs?
Balance would be cleaner?
Edited by Hawaiiancerveza - 8/7/12 at 2:58am
post #2373 of 2549
I was wondering guys, does constant bottoming of this sub damage the sub? I ask this because I just watched X men first class on BD and that movie had my dual drive singing but I kept hearing like a bottoming noise all the time whenever the action (on the sub channel) got extremely violent. My subs' gains are too high (12 o clock) but that is where the AS EQ1 advises to put the gains. Should I be worried about the noise ( I know I should be worried) because they can damage the sub?
post #2374 of 2549
I answered this in the AS-EQ1 thread.
post #2375 of 2549
thanks Jerry. I appreciate your efforts but I asked here because I wanted to know if it could damage the sub?
post #2376 of 2549
If your subs are really bottoming out, yes, you could be damaging the sub. You could be stretching out and tearing the spider or the voice coil could be hitting the back plate and warp the shape of the motor. You should either get more subs, or get more powerful subs, or turn the volume down. Since bottoming out tends to only happen in the low frequencies, one thing you might do is turn the ULF trim up- my understanding is this will roll the sub off higher.
post #2377 of 2549
I am working on a larger theater room roughly 17X14 with 9 foot ceilings and have a ED A3-300 that currently in my family room . I have heard a few sealed subwoofers in the past and appreciate the sound especially since I listen to music and movies 50/50 .This is the leading sub of choice for me since I use hsu speakers and although I have never heard it there is concern whether I will be happy initially with its music and movie presentation compared to the ED unit. I eventually on the flip side want too get second unit but need to take care of other items for this room.
post #2378 of 2549
I have owned both the A3-300 and now own some ULS-15s. While the A3 is a good sub, the ULS subs are substantially better. Be aware that a ULS won't get a whole lot louder than the A3, especially at the A3's tuning point. If you want something that has straight up more output than the A3, get the VTF15h. If you want something that has roughly similar output but much better sound quality and better feature set (not to mention looks much nicer) then go for a ULS. Two ULS's is ideal because there you get bigger output alone with sharp sound quality.
post #2379 of 2549
Yes, you can definitely damage the subs.
post #2380 of 2549
Awe man... I tried to order this sub but Hawaii isn't an option....I can't get the sub...
post #2381 of 2549
just swapped the Y connector from sub1 with the one from sub out 2, will monitor
Any follow up to your humming issue?
post #2382 of 2549
We do ship to Hawaii, but it's expensive. Simply email sales@hsuresearch.com your full address to get a shipping quote.
post #2383 of 2549
Do it. It's worth it. Hsu customer service is second to none.
post #2384 of 2549
I wrote to them. Now I'm waiting impatiently...lol
Edit: I got a quote, and its a bit much for the package I was looking at. Ill see how much it is for just the ULE-15.
Edited by Hawaiiancerveza - 8/14/12 at 7:49pm
post #2385 of 2549
Well after reading this thread over the last month and getting some first hand experience from some of you guys and talking with hsu who I already use for there excellent bookshelf speakers I am upgrading to the ULS-15 with the eventual thought to add one more down the road once I do a few other things in my listening room smile.gif. My reasons are although I have been happy with my current ported sub which is moving to another area sealed subs have always sounded a bit better to my ear .Seems over the years and into my 4th subwoofer evolution I always get talked out of them until know.
post #2386 of 2549
i'm still waiting on a response about shipment for the ULS alone.
post #2387 of 2549
Hey guys, Tron is a movie that i think all persons in here should try especially the quad owners. It was so brutal i actually turned it off for fear of damaging my already "limited" system.
post #2388 of 2549
Hi Kimwyn. Did you mean Tron: Legacy? If so you should try Battle: LA. In some spots of the movie it is even better then Tron.
post #2389 of 2549
I always use this movie to test the Quads.
post #2390 of 2549
It will test the output capability of any sub, but I must say it is so bloated that it does NOT show the SQ (sound quality) of the subs... biggrin.gif
post #2391 of 2549
Funny you should say that cause i was thinking the same thing......hehehehehehe
post #2392 of 2549
It does in the bar scene
post #2393 of 2549
Well Just got my ULS today and I am impressed already with the fit and finish instant WAF. Without a full calibration it sounds exceptionally better than my previous Subwoofer and was stated pretty well by ShadyJ ( thanks for the feedback). The low frequency output just seems to go to gutter smile.gif levels but it so smooth/effortless and thats just off of some instrumental contemporary Jazz Music I popped in for a bit. This weekend I am going to set it up properly but I can tell you all that eventually I want to get (1) more to even things out in my room.
Dr. HSU you have a winner here in this sub!!
Edited by wkingincharge - 8/22/12 at 6:57pm
post #2394 of 2549
Thank you for your kind words! Glad you liked it so much. Welcome to the Hsu family!
post #2395 of 2549
Well Just got my ULS today and I am impressed already with the fit and finish instant WAF. Without a full calibration it sounds exceptionally better than my previous Subwoofer and was stated pretty well by ShadyJ ( thanks for the feedback). The low frequency output just seems to go to gutter smile.gif levels but it so smooth/effortless and thats just off of some insturmental contempary Jazz Music I popped in for a bit. This weekend I am going to set it up properly but I can tell you all that eventually I want to get (1) more to even things out in my room.
post #2396 of 2549
^^^I can only imagine what (4) of these monsters would sound like going in unison biggrin.gif ^^^
post #2397 of 2549
Anyone in here running dual ULS on one single 15 amp circuit? Is that possible? would it damage the subs? would it cause any trips in teh circuit?
post #2398 of 2549
I have. No problems. So, it's possible.
Hope this helps.
post #2399 of 2549
Thanks WTF. But my question is, how hard were you driving the system? What kind of spl levels? I would assume that makes a huge difference, doesnt it?
post #2400 of 2549
I think there are too many variables for me to try and give a simple answer. As a general frame of reference, I have two ULS-15s and 2 MBM-12s on a 15 A circuit. I use Audyssey calibration with the conventional crossover of 80 Hz and cook the bass 3 dB hot in a medium-sized room that is open to the rest of the house.
