OK, Here's where I stand right now.
I have a 32" 1080p Sharp Aquos LCD, and an SA Explorer 8300HDC. I decided that because there was no upfront cost, I would have Wide Open West, (formerly Americast a really long time ago,) provide me with an HD DVR.
I'm planning to evaluate this unit, for a while and make a decision as to wether I want to keep it, or switch to an HD Tivo.
FWIW, If I'm reading the screens correctly, It's running SARA v1.90.5.a116
It does not seem to be recognizing the 1.5TB drive I attached to the Esata port, (A seagate FreeAgent Pro) the drive came pre-formatted as NTFS. from what I can tell, as soon as I plug the thing in the box should ask me to format the drive. but this is not happening... any ideas?
Second, Is Tivo compatible with multi-stream Cable Card? the Tivo units I saw at best by say "2 cable card Slots" so I'm assuming not. Is there news of a multi-stream Cable card compatible Tivo in the works?
If I had a Tivo, does it have two F-type connectors? I ask because there are a couple of PBS stations I can recieve OTA, and both are on the analog programming block, and they have different programming, but there is only 1 each of Fox, CBS, NBC, and CW in the HD block. I also don't have access to the OTA sub channels.
If I get a Tivo and only put one cable card into it, the Tivo still has two tuners, will it still be able to record two channels as long as one of them is either basic analog cable or clearQAM?
Next, regarding conflict resolution, two shows that I really like have been moved into the same time slot, (Chuck, and House M.D. FWIW) If I have both of those set to record, and if a third show comes into conflict with that time slot, will the Tivo, (or the SA box) for that matter give me a message when it gets the new schedule information?
Regarding new content on the discovery networks: at present, Discovery network channels only have half of a prime-time block and air the whole thing twice. it looks like, at present time, I need to choose between only getting new shows only in the first airing, or recording all shows, from the second airing. (frankly, I think instead of a single bit "New" flag we should have a "First Air date" timestamp, to aid in such conflict resolution.) now the question is: Is the Tivo smart enough that if say a new episode of Mythbusters is airing at the same time as new episodes of Chuck, and House, will it be smart enough to see that the description of the later show is the same and record the later one instead?
Finally, my old SD DVR is a ReplayTV 5040 unit, (upgraded to 300GB) and it allowed me to program the guide to "ignore" certain channels. they would not be searched, they would not show up in the program guide, and they would be skipped over if I was using channel up and down on the remote. I programmed my Replay to ignore channels I never watched, including QVC, premium and HD stations I couldn't get and the music channels. Can I do the same with the SA box or the Tivo?
Thanks for your help.
