EDIT
Thanks to KewlK the overscan problem mentioned in the OP has been evened out on the 1080i input, and I have to go in and adjust the amount in the other resolutions, however a further geometry issue has been realized, outlined in this post below.
Main Issue
I know these TVs have always been a "fun" topic here, but lets keep the typical haters out, I'm looking for people with experience with this issue.
On Tuesday of this week (4/21/09) I had my OB replaced for the first time on my June 2006 built KDS-R50XBR1 due to the green blob issue.
I was here for the replacement and everything looked fine, and immediately post replacement the tech reset my settings and we connected the HD cable box and PS3 to take a quick look and the difference was obvious immediately (just switched to default pro to check). He packed up and left and I didn't get a chance to really calibrate after that.
On Wednesday I got a chance to run the HD-DVD version of DVE from the 360 add-on. When I got to the geometry images I immediately noticed how off the screen was.
I tried changing resolutions from the 360 to 720 and 1080 and the problem was persistent. However since my 360 (component input) was replaced in between my last calibration and the OB replacement it was possibly a defect of the source, so just to eliminate that (and since my BD DVE won't arrive until later today), I downloaded the HDNet patterns and streamed them through my PS3 (HDMI input) and saw the same results.
I then decided to do a less scientific method and hit up Xylon's WALL-E comparison thread. I used the first image of WALL-E with the hubcap since it had too reference points on the picture, and I could easily see just how much of the screen was missing. It's OK on the left (about the maximum "ok" overscan, but still more than previously, and I'm not happy with it), however the right is missing approximately 1.65" to overscan. I have attached an image that displays what I'm seeing using Xylon's original.
The top is pretty much fine, but the bottom is missing about 3/8" to 1/2" inch as well.
Now this seems really odd to me on a non CRT display so the only thing I could think is that either the block isn't seated properly (which I don't even know if it has the room to NOT be seated correctly), or the projector in the block is defective.
I called the repair service back and talked to the tech who basically said he never had a replacement customer complain of overscan problems, but also admitted he didn't know of any who were using geometry patterns to calibrate either. He said I should call Sony back since they covered it.
I did that, which was the typical CS exercise in frustration with a lackey typing stuff in and (painfully) reading it back to me like a robot, he then recommended I call the repair service, and I told him I did, and they said to call him, and then he just repeated himself (the fun part was when I mentioned calibration, at which point I imagine he typed in the word "calibration" and he got a screen that he read about how sony doesn't cover the work of calibration services... I laughed at him pretty hard).
So I just called the manager of the repair place and he listened to the problems and said they'd discuss how to proceed (stating that he didn't feel he needed to come out with the level of checking I did). But I figured someone here might be familiar with why this is happening so I can account for any possible BS I might get fed.
Reference Image of what I'm seeing
Secondary Issue
I honestly can't remember if this was a problem or not with my first block, but when calibrating the color settings using DVE and the filters, Blue and Red were simple to balance, and green is off by quite a bit no matter what settings I change. I read a few threads on this and it seems to just be the way it is, but any comments on that too?
Main Issue
Secondary Issue
