Originally Posted by MD Boy
Hello knowledgeable gents',
Long time reader here - not so much on posting because I don't have a lot of knowledge to share
Given that, I was hoping you might be able to help me out with a few questions. I skimmed through this thread as much as I could before I started asking questions.
Just hooked up to my BDP-23fd over the weekend and am liking it so far. Audio is great. Video....has left something to be desired. Colors are kind of dull. I have everything connected via HDMI. Player is connected to a Pio Elite VSX-23 connected to a Kuro Plasma.
Any suggestions on how to adjust the colors? Colors look a bit, 'washed out'. Definitely an upgarde of SD - but not entirely what I was expecting.
Also, last question, I have, 'PCM' showing up on my receiver when watching a BD. Is that fine/what it is supposed to be showing?
Thanks in advance and I appreciate any help (sorry for the long post)
Michael
Given that, I was hoping you might be able to help me out with a few questions. I skimmed through this thread as much as I could before I started asking questions.Just hooked up to my BDP-23fd over the weekend and am liking it so far. Audio is great. Video....has left something to be desired. Colors are kind of dull. I have everything connected via HDMI. Player is connected to a Pio Elite VSX-23 connected to a Kuro Plasma.
Michael
PQ is dependent on a few varied factors. One of the first things being your personal preferences. What's dull to you may be spot on to others who want a more natural look and less "pop." Another thing is not all BDs are created equal. The gamut of PQ in BDs will run from ok to outstanding depending on the transfer. And when they're just ok, they're only marginally better than their DVD counterpart.
But aside from that, with your equipment you should be choosing Pioneer PDP or Professional from the Video Adjust menu. In addition, you may also have to calibrate your display. One of the really nice features of the PIO BD player is that if you are not satisified with default vanilla video adjustments, you can tweak them with that same Video Adjust menu. Just make your adjustments and they'll be stored in Memory 1,2 or 3.
As for audio, to take full advantage of your equipment and the lossless codecs such as Dolby TrueHD and DTS-MA, you should select "Auto" for HDMI Audio Out. I would also make sure to set HDMI high speed transmission to "On." BTW, your VSX-23's display will show the correct codec for that particular BD ie; Dolby TrueHD or DTS-Master Audio, instead of PCM.
Mike T
I normally don't mind a layer change of less than a second but, 1½ to 2 second is a little on the long side.
