Originally Posted by Saturn94
Video out - 16:9
4:3 video out - full
HDMI hi speed - on
HDMI color space - RGB 16 to 235
HDMI audio out - On if you want sound thru the tv, Off if not (I have mine set to Off)
Kuro Link - I don't use this, so I have it set to off.
Playback still picture - Auto
Angle/secondary indicator - Off
Hybrid disc playback - BD
BDMV/BDAV Playback priority - BDAV
Sorry for the delayed response. Hope this helps.
Video out - 16:9
HDMI hi speed - on
No problem.
I have most of those set to where you have them set to, except...
4:3 video out. Mine is set to Normal. I was told by someone else to set it to Normal. Normal (black bars are shown on the left and right as it should be on a 16:9 screen).
BDMV/BDAV. I was told on here to set it to BDMV because all commercial BD movies use the BDMV structure.
Mind you, my Kuro plasma tv is NOT hooked up to any reciever or amp, just a Pio bd player.
) which is why I have it set to Full. I know it makes no sense (what humans do often doesn't
As I understand it, if you want the BD player to add black bars to the sides of 4:3 content to maintain OAR then your setting is correct. Of course even with 4:3 set to Full, the same thing can be accomplished using the settings on the Kuro. Now that I think about it, I want to say setting it to Full had something to do with properly displaying non anamorphic DVDs, of which I have a few. You could certainly try both settings and see what works best for you.
