AVS › AVS Forum › Audio › Speakers › Help with bedroom speaker solution
post #1 of 4
I have a commercial model plasma (no speakers) in my bedroom. Currently I'm using the Bose Companion 3 as a simple speaker system. This worked fine when I was a Time Warner subscriber and could control the volume thru the cable box.
Unfortunately, I just switched to DirecTV and discovered that my box has no volume control. So I am left with a wired remote control (the Bose "control pod") solution, and the wire barely reaches the bed.
Can anyone recommend a speaker system that is:
1) simple (2-3 speakers max, preferably self-amplified so I don't need a receiver, since everything sits atop my dresser)
2) cheap (since I already dropped $250 on the now-useless Bose)
3) comes with a wireless remote?
Thanks everyone.
post #2 of 4
Look into sound bars. They do the same as a Bose, but sound better.
post #3 of 4
Well, soundbars aren't cheap, but one should meet your needs.
How about professional active monitors?
I was looking at these JBLs recently:
http://www2.jblpro.com/catalog/gener...?PId=280&MId=5
There are lots of other options available, but it's hard to beat JBL's engineering resources.
post #4 of 4
The best powered speaker I know in that range is the Audioengine 2.
http://www.audioengineusa.com/a2_home.php
or if you can swing it, the Audioengine 5.
http://www.audioengineusa.com/a5_home.php
  Back to Forum: Speakers
