OK I am having major issues and can find no way of testing or verifying what is wrong with my new PC
Everything works great except for sound over HDMI. If someone can help me I'd be very grateful!
I have a brand new PC with Gainward 9800GT card (with HDMI output, via mobo spdif header wire connection) running with an Intel DG45ID mobo with WinXP SP3. Mobo runs IDT HD udio codecs. Vid Card has no audio settings I can find anywhere.
I have got a lovely 1080p picture via HDMI on my Phillips Cineos 47" LCD TV (HDMI 1.3 compliant) via the 9800gt's HDMI output. No matter what settings I have found and played with, and with multiple reboots etc, I cannot get a peep of sound from the TV via the PC's HDMI link. I don't have any other HDMI devices to test on the TV's inputs, or any other means of testing the computer's digital optical audio outputs. I have checked the wiring on the mobo to video card and all looks in order. I have updated all drivers. I have even flashed the TV's firmware to current.
Can anyone suggest a way of determining what is wrong? I am getting good anologue audio from the PC, i can send some program's sound output to SPDIF (anologue cuts out) but stull nothing from the HDMI output via spdif mobo passthrough. I can't find anything that specifically mentions "HDMI" on any drivers or audio settings, for that matter either, only SPDIF.
What am I missing?
I do not want to have a long run of analogue audio running seperatly to the TV to get my sound. I want to use the PC/TV link to play recorded HDTV (have a leadtech HDTV capture card) via HDMI only.
The only thing I can think of trying is ripping out the 9800GT and seeing if the mobo's HDMI is outputting sound....
What am I missing?I do not want to have a long run of analogue audio running seperatly to the TV to get my sound. I want to use the PC/TV link to play recorded HDTV (have a leadtech HDTV capture card) via HDMI only.
