Originally Posted by
gregr
The clipping still exists after the firmware upgrade. The upgrade has no effect on the clipping.
Set all of your sources to Standard and then set the projector to Enhanced and adjust the projector once. You won't need to adjust any of your sources (which is usually not a good idea).
Thanks Greg, but that's not my experience.
With the original firmware, my BD-50 in standard mode and the PJ set to standard as well was clipping BTB (not visible on a pluge even with brightness pumped up). The only way to get it to show was to adjust settings on the BD-50. Same for WTW.
With the new firmware, BTB is visible if one pushes brightness above the default of 0 (HDMI standard for both BD and PJ). Although it could be an automatic update of the BD-50 firmware that happened more or less at the same time? I'll double check this.
I'll try to set the sources to standard and the PJ to enhanced and adjust constrast/brightness, that is something I never tried as I thought source and display had to match, thanks very much for the tip.
Edit: tried your advice to set all sources to standard, PJ to enhanced and adjust once. This seems to work very well, thanks.
Re clipping, it looks like your were right, it is still clipping with the new firmware. I have no idea why it stopped clipping at some point (or why I think it stopped). But the fact is it still clipping. Thanks for correcting this.
