Hi KT.
Yes, no compression on the color ramps (although I'm using the 6 colors pattern on AVS HD, I could't find any color ramps on the DVE Bluray (I've got the basic edition). I would need to push contrast up to 15 to start seeing any significant compression on the color ramps. But on the grey ramps, anything above 8 starts to compress WTW. I chose 4 because it didn't clip anything and "felt" right. I guess up to 6 or 7 would be OK if one wanted to maximise the light output.
I use The Dark Knight to check details in dark scenes, and Happy Feet to check contrast settings.
By the way, another way to check patterns without an Accupel is to use the free pattern generator from the folks that make Calman with an HDMI equipped laptop (I have a Sony Z25). Not as versatile, precise or accurate as an Accupel, but it's really handy if you want to check with a different source than your BD player. It's just important to make sure that the HDMI setting on the driver (nvidia for the Z2x) is on the correct HDMI range.
