Got my Sharp HT-SB200 today. I hadn't been able to find any user-type reviews of this particular soundbar, and as such figured I'd snap some pictures and give my initial impressions.
Efficient packaging. Not much waste.
Couple shots of the contents of the box. The power supply is a brick that sits behind your TV somewhere.
Rear shot- standard inputs, pair of RCAs and a 1/8" jack. RCAs represent input 1, 1/8" for input 2.
And heres a shot of the bottom. If you're not wall mounting it you have three choices - two different sets of legs ("Spikes") or it also has stick-on feet.
The back has insets for wall mounting brackets, which are included.
And here's the front.
Here's the spikes. I ended up using the smaller of the included spikes to pair with my set.
And here it is, all installed and ready for action. Pictured is my 52" Sharp LC52D65U set.
Overall, I find it to be a simple, elegant solution to having audio that is a few steps up from out-of-the-box tv speakers. I look at as giving a bit extra bass and some "dimension" to the sound, I'm not sure exactly how to express it, but it's good.
Maybe some advice??
If anyone finds the code PLEASE post it widely.
