AVS › AVS Forum › Display Devices › Rear Projection Units › HELPT!! Can't Change INPUTS (Mitsubishi 73" DLP)
post #1 of 4
I have had my 73'' Mitsubishi DLP, 73727, 1080i for about 2 years now, never had a problem.
I recently switched my HDMI input to ANT1 input to play my original Nintendo NES on 73'' of fun. When I was finished, I tried changing my input back to HDMI, but I can't.
PROBLEM:
Everytime I press "Device" (to change inputs) on the TV, it freezes for a few seconds, and then shuts off.
Everytime I press "Input" (to change inputs) on the remote, the screen turns blue.. then shuts off.
I pressed the reset button on the front of the TV, but it doesnt do anything but change my video setting back to default.
PLEASE IF ANYONE CAN HELP ME. I am stuck watching TV on my ANT1 input and it is driving me crazy! Thanks for your time.
post #2 of 4
Press the GUIDE and FORMAT buttons on the front panel to reset all A/V Memories to the default settings.
If that doesn't work:
On the remote press Menu 2 4 7 0 , hightlight Initialize and press Enter. Wait for it to finish and press the RESET button on the Tv.
If that doesn't work...
post #3 of 4
I'll try it now, *crosses fingers*
I'll let you know if it works.
****EDIT****
THANK YOU VERY MUCH!!!!!!!!!
YOU DONT KNOW HOW HAPPY I AM!!!!!!
THANK YOU SO MUCH!!!!!
post #4 of 4
I know this is old but here we are 3 years later and this helped me big time. I was panic'd big time worried about having to buy a new TV. Thank you for the quick and easy fix. This worked on my Mitsu 62" TV.
  Back to Forum: Rear Projection Units
