Originally Posted by
cornelious
I got a new PC, and i realized that i have lost the Pixela disc that came with my HF10. The PC recognizes the camera, but I cant transfer movies. Is there another software that will do this? I'm sure there is, but I'm a bit lost.
If you can see the file structure on the HF10's internal drive while connected to pc/or card in camera through USB ..or card in pc card reader...
..then
copy only (
important: don't "cut") the "Stream" folder and paste it onto your pc hard drive. This has the .mts video files.
Then disconnect the USB via safely remove hardware, turn the camcorder off/put aside..
You can then import the mts files on your pc hard drive into an editor like Pinnacle, etc. (program needs to be able to work with AVCHD).
Or convert the mts files to another format with a free (or paid) file converter.
Otherwise, I think you can purchase the Pixela CD again and, if you do; make sure to make a backup copy.
