AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sharp Aquos LC46D85U
post #1 of 2
The AQUOS D85U series HDTV LCD sets a new standard for large-screen flat-panel TVs. With Full HD 1080p resolution and an elegant new design, it produces a breathtaking picture quality that is second to none. The D85U Series utilizes Sharp's proprietary Advanced Super View/Black TFT Panel with Spectral Contrast Engine, providing high Dynamic-Contrast Ratio, 4ms response time and 176-degrees wide viewing angles. In addition, the D85U models include 120HZ Fine Motion Enhanced for the ultimate in fast-motion image processing. All models are HDTVs with built-in ATSC, QAM, and NTSC tuners and include 5 HDMI inputs, compatible with 1080p signals, and 2 HD 1080p component video inputs. The D85U Series features a sleek piano black cabinet with subtle recessed bottom-mounted speakers. The included table stand easily removes for wall-mounting applications. The D85U uses a 10-Bit ASV LCD Panel from Sharp's state-of-the-art Kameyama factory, with Active Color for a more lifelike picture, Active Contrast for truer blacks, and a fast response time. 3-Wavelength Back-Light System
post #2 of 2
Welcome to the forum!I'm completely satisfied with the Sharp Aquos LCD TV. I looked at many brands, including both the Sony and Samsung. Both are considered top of the line TV's.The picture quality is outstanding.The 10 watt sound system is a bit weak, but if you're going to hook it up to a home theater system, it doesn't really matter. Sharp has a 1 yr warranty that they'll extend to 15 months just for enrolling in the Aquos Advantage program.Thanks........
