I have a Vizio VP322 HDTV10A, p/n: 10123020022. The neighbor was throwing it away so I figured what the heck. I'll try to fix it. The initial symptoms that were given to me are the TV wouldn't power on at all. No orange stand bye Vizio light, no nothing. After reading several forums I took the back apart and sure enough there were two bulging 3300uF 10v capacitors (C233 and C234). I ordered two replacement caps and changed them out. After getting everything back together the stand bye Vizio light would come on/turn orange and everything returned to normal. IT WORKED!!! Unfortunately, my confidence was cut off as the Vizio light below the screen stayed white like the TV is on, but the picture goes away/turns black after 10-20 mins of operation. (Not sure about sound). There were no other visibly bulged/damaged caps on the power supply. So again hitting the forums I ran across a repair kit offered by LCDAlternatives
http://lcdalternatives.com/Repair-Kit-Vizio-VP322-Plasma-TV-Capacitors-P1699285.aspx that comes with all the following caps (C233 and C234 3300uF 10v, C236 1000uF 10v, C201 47uF 100v, C206 100uF 16v, C241 470uF 10v, C204 and C205 1000uF 25v capcitors). The kit is good, but now after replacing all these caps the display will not even turn on for the 10-20 mins like before.
My current symptoms are the Vizio light turns orange in stand bye mode, once the power button is pushed the Vizio light turns white, a relay clicks, the D104 LED on the main logic board turns solid Green/yellow, followed by the D201 turning Green/yellow blinking once/second 3x, the display attempts to turn on/flashes grey, the Y-sustain board starts to buzz like power is there, within 1 second the relay clicks again, the display quickly goes black/blank, both the D104 and D201 LED's on the the main logic board go out, the Vizio light below the screen stays white. It's almost like the picture trys to load, it can't, and therefore a safety shut down occurs? Any help moving forward would be appreciated. Or there might be a video post on here of a 32" Vizio tv flying from a second story balcony. Thanks!
Edited by frantzray - 12/26/12 at 1:27pm
