AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Upgraded to HDMI - Now having sound issues
post #1 of 6
Longtime reader here and my first post.
I usually can figure out home theater issues, but this XBox problem has me baffled.
I had been using component cables from my XBox 360 to my Sharp LCD but encountered a display "reset" every few minutes that lasted for about 3 seconds each time. I did some research and found that a HDMI cable should solve this.
Got the cable with the audio dongle in today and promptly replaced it. I have Astro headphones that plug into a mixamp with Dolby Digital via an optical cable. So I ran the HDMI to the back of my TV, used the dongle and plugged my optical cable into that and then the other end into the mixamp which my headphones plug into.
When I turned on the Xbox and popped on my headphones I had no sound - EXCEPT for chat voices (I was playing an online multiplayer game). I heard and could speak over voice chat but had absolutely no game sound. I turned off my Xbox and then back on and now have no sound at all.
Now, after some reading I've seen that there used to be a bug with the new Xbox dashboard but I thought I read that it was fixed. Any ideas? Any settings I'm missing in my Xbox? Very frustrating, to say the least.
Thanks for any help.
post #2 of 6
Join the club. I'm using straight up HDMI for both audio/video to my Pio HDMI receiver and I'm getting the opposite of you.
I can hear the game/movie audio fine on my 5.1 setup but I'm not hearing any Live chatter. I do have noticed that the CoD4 scoreboard indicates I have a headset (indicated by icon next to my gamertag) while I don't.
I personally think the 360 is not very good at handling HDMI. I had a PS3 for a short while and I never had such HDMI behavior with that. I'm thinking of going back to component/optical but I do like the slight sharpness over HDMI though.
post #3 of 6
"the 360 is not very good at handling HDMI."
No. HDMI is not very good at handling HDMI. It's the stupidest goddamn video standard ever that has caused far more user annoyances than anything that come before it.
post #4 of 6
Unfortunately I don't have the option of going back to component/optical because of the flaw in my TV with the Xbox connected via component. But, I did find a solution (so far):
I read up on the Xbox Dongle used to hook up optical while using a HDMI cable and found that you can bypass using a dongle by prying the cover off the end of the original cable that came with the Xbox (the cable that has the optical out). [I have a link in the next post on what I'm talking about since you can't post links unless you have 3 posts or more in these forums.] After prying off the cover of the orginal Xbox Cable and plugging it in along with my HDMI cable (it's a very snug fit, even without the plastic covering, but I got it in there) it works, which leaves me two conclusions:
Either I had a faulty dongle OR the dongle just doesn't work correctly when trying to run your audio through optical and using the HDMI cable for video purposes only.
Either way, it's working well, so far.
post #5 of 6
Here is the link on how I removed the cover on my orginal Xbox Cable to allow it to fit along side my HDMI cable - http://www.chadledford.com/?p=50 .
post #6 of 6
Sounds like you got a fualty dongle as many of use HDMI for video and optical for sound, as the HDMI + 5.1 on 360 doesn't seem to work well or most of the time.
  Back to Forum: Xbox Area
