AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Toshiba lcd tv ?
Toshiba lcd tv ?
post #1 of 8
I am going to buy either the 47ZV650 LCD HDTV or the 46XV645 LCD or the HDTV 46SV670 LCD HDTV
I am not technical can anyone tell me if any of theses models have led back lighting please
post #2 of 8
just include model names plus the word blacklight or feature and do a google search.
post #3 of 8
just include model names plus the word blacklight or feature and do a google search [img]http://imagesshack.info/************[/img]
post #4 of 8
I am not technical can anyone tell me which model has led back lighting I tryed google
post #5 of 8
if you can't use google how are going to manage using the remote control?
The fisher-price range has backlight LCD
post #6 of 8
I tryed google did find the models I am not tv technical can you tell me which model is the led
post #7 of 8
I think you mean "tried" not "tryed." By the way, if you aren't technical, why do you even care about which model is the LED? Perhaps you should go to the Toshiba website and start your research there.
Good luck to you.
post #8 of 8
Here you go...
The new top of the range Regza LCD HDTV from Toshiba is the Toshiba SV670 series. The SV670’s make great use of the new FocaLight LED backlight technology. The LED backlight with local dimming offers a full matrix of LEDs which can dim independently of each other to create a much higher dynamic contrast ratio for improved colors and image quality. Simple edge LED lighting does not offer this feature.
The Toshiba Regza SV series will be available in two large sizes, as the 46-inch Toshiba 46SV670U and as the 55-inch Toshiba 55SV670U, both models should be available in May 2009.
Found it here.... http://www.hdtvlounge.net/toshiba/regza-sv670/
Looks like the 670 and 645 are both LED, the 650 from what I saw is not.
