Originally Posted by wtwieder
If you are having loading issues with your discs, return the player. Those issues will not be fixed by firmware updates.
My first BP1600 had trouble loading discs. It was replaced and the new one has never failed to load a single title.
It is a known problem with all of the Samsung Blu ray models that the the quality control suffers. If you lose the crap shoot and get a bad player, either return the player to the dealer for an exchange, or if you can't, return it to Samsung for repair. If you are returning it to Samsung, include a disc that isn't loading. Loading issues are commonly reported with these players. It could be that there is a slight alignment probem with the lasers so that marginal discs have problems loading. In extreme cases like my first player, after owning the player for 3 weeks, no discs would load.
BTW, the DVD upscaling on the current crop of Samsung Blu ray players is less than great. Pixillation issues are commonly reported with DVD. This was the only issue CNET testing had with the the BP-1600 (essentially the same player as the BP-1590) and the BP-3600. (Fortunately, Bluray performance is great with no pixillation problems) The DVD performance of my BP-1600 bothered me so much that I purchased a separate upscaling DVD player, the Samsung DVD-1080p9. There is a night and day improvement with this dedicated DVD player over the Samsung Bluray's DVD performance. The nice thing is this DVD player only costs about $68. It was well worth it to me.
Thanks for the input. I have had hardly any problems with blu, but dvds are problematic at times. I had been using my xbox 360 with HDMI for dvd. I will either have to return the blu ray player to the seller on ebay or send it to Samsung. I'll think about this.
