Originally Posted by
davidyal
that's a good idea. I'll try the attic first as well. My coax from the antenna needs to amplified. Is it better to amplify in the attic right where the signal comes in from the antenna, or downstream near the TV itself?
well....at only 17 miles distance i doubt u need an amp...try it w/o one first....amps can overload from all kinds of other local signals...like nearby fm radio stations, etc etc....plus an amp can develop weird problems over time from aging, etc etc....and like hard drives, every amp will die sooner or later....a totally passive antenna system is always best....
and b4 u buy an amp check your coax type....is it rg-6 or rg-59? look on the jacket cable....hopefully its printed on it....if its rg-6 u should be ok....but if its rg-59 and and u have a cable run longer than about 40 or 50 feet u might avoid having to use an amp just by switching to the lower loss-per-foot rg-6 coax....rg-59 gets to be very lossy at the higher uhf tv frequencies...and if u have a really long coax run, like 150 feet or more, rg-11 coax might be a good choice....
and if u do need an amp do
not mount it in the attic....the summer heat in an attic is murder on the amps circuitry....
