OK, so you could like
follow the directions and use the file linked to in post #386, or you could do it my way via the Dune let's dork the box and luck out and recover it but never quite get it working as a pch route . . . I suggest the
follow the directions route!
I downloaded the proper file and it updated as normal and when it rebooted it was a popcorn hour!
I even hit the check for updates button over in the maintenance section and it found and updated the firmware without issue!
So far so good, I couldn't find anything that didn't work as normal and it even kept all my network shares, settings, etc. just like a normal firmware update. I don't have a hard drive attached to this unit though so I couldn't test the sata port, I will shortly though and I'll make a point to use it a bit just to make sure everything is working fine but from everyone else's experiences I'm sure they will.
Thanks guys - I appreciate it and I humbly apologize
for not following the directions in the first place!
