Originally Posted by iranintoavan
EDIT: I kept messing around and the thing that crashes my whole network is when the Coax LAN on the upstairs actiontec is activated. Whether that be when you turn the actiontec on, or if you have it on and then plug the coax cable in. Once the router is off everything works again. However when I have it on and connected to my laptop, I am still able to access the downstairs actiontec settings, so it is obviously reaching the other router somehow. But it just messes up the internet connection.
Hopefully I can get this figured out, its frustrating getting something new and not being able to play with it yet!
It sounds like you and npradeepkumar are having similar issues. What cable modem and router do you have? What are the IP addresses of your cable modem and router?
My router assigns addresses/static IPs as 192.168.1.x. I know some other brands use 192.168.0.x. My instructions have you assigning a hard IP assuming it should be 192.168.1.x - perhaps that is an issue?
If you just connect the actiontecs together with a piece of coax (not through your house wiring) does it work fine?
xnappo
