Guys,
I've got a problem. This is not directly related to the Actiontec MI424WR router; but rather a MoCA issue. However, someone advised me to ask here as someone might be able to give me a solution to my problem.
I just bought the NetGear MCAB1001 Kit & installed it yesterday. One adapter downstairs in the family room with my Cable Modem/Router & all ... and the 2nd adapter upstairs in my master bedroom. The idea was simply to provide my Dune Smart D1 with enough bandwidth to stream Blu-ray ISO's.
It worked! The 2 MoCA Adapters connected and I was able to stream Blu-ray flawlessly. BUT - It killed my Cable TV - Completely!!
It was so bad that as soon as I had both MoCA Adapters connected and they passed data between each other - my Cable TV died!! And as soon as I unplugged the main MoCA Adapter -- Cable came back on!! Tested couple of times to make sure.
Let me give some details of my setup.
I have Comcast Digital Cable Service. The way my family room is setup is this ...
A Coax cable comes out from the Coax Outlet.
This cable connects to a 3-Way Splitter (Brand New / Recently Installed).
- One end goes to a TV in the adjacent room
- One end goes to the TV in the family room
- One end goes to my Cable Modem for Internet
Per the instructions, I connected the first MoCA Adapter with my Internet Cable Modem. It is here that if I plug in & turn on thej MoCA Adapter - the 2 televisions that are connected to the same splitter STOP recieving Cable TV. If I unplug it, Cable TV comes back on.
This is the 3-Way Splitter Installed:
PCT-NGNII-3SB
Genesys II
3-Way Balanced Splitter
5-1000MHz -130db RFI
Prduct details: http://www.pctstore.com/3_way_splitt...ctngnii3sb.htm
I had read in many places that if you have such & such splitter or amplifier - this product won't work! Well - In my case the EXACT OPPOSITE is happening. This product is working just fine - it's my Cable TV that's dying.
While I was streaming Blu-ray or simply transferring even basic data over this MoCA Network - my Cable was dead behind.
Per the manual & instructions that came with the NetGear MCAB1001, I checked and made sure under Coax setup, I had the Diplexer Mode set to "Moca D Band" and not "ALL PASS" (Which does apparently Kill Cable TV). And also that Frequency was set to "SCAN". Both are correct and the way they should be.
Can someone here tell me if it's the splitter that's the problem or something else? Or if I need some other kind of splitter or diplexer or something?
Thanks Guys!!
PCT-NGNII-3SB
Genesys II
Thanks Guys!!
